Factor Ostro
kode54
by kode54
Factor includes 24mm adapter cups (or reducer cups) to fit Shimano cranks onto a 30mm bottom bracket.
- Factor Ostro VAM Disc
- Factor LS Disc
- Specialized Aethos Disc
- Sturdy Ti Allroad Disc
- Guru Praemio R Disc
Knightyboy27
by Knightyboy27
1sanglier wrote:
Wed Jan 04, 2023 9:51 am
Thanks, don't exist for 24mm :( .
Yes they do
https://rotoruk.co.uk/v1.asp?cat=1054&prd=276556
flmo
by flmo
Hi. Received my frameset recently. It might be a stupid question, but is it normal to have a hole on the bottom of the frame? If yes, do you tape this to prevent water going in?
robbosmans
by robbosmans
yes that’s obviously normal, so water can get out of your frame
tmanley
by tmanley
Yesterday I mounted a pair of 32c Vittoria Corsa Next tires (on Enve 2.3 wheels) and found they had plenty of room on the 61cm frame. Anyone using a 61cm frame try something larger?
I'd be curious to see if the 34c Corsa Next's could work or even the 35c RH Bon Jon's.
-Thanks, Todd
MysticRiver
by MysticRiver
engsohere wrote:
Fri Jul 29, 2022 10:12 am
Rkreddevil wrote:Hi,
I'm planning to buy Ostro Frameset, does the frameset come with t47 bb for either Shimano 24 or Sram dub. Does the frame have standard t47 bb? Is anyone running rotor carbon cranks with 30mm spindle. If yes, which bottom bracket are you using?
As others have mentioned, it comes with 29mm and 24mm reducers. If anyone's thinking about using GXP go with these ones by Prime. They're made of aluminum, not plastic resin and there's a rubber gasket and seal.
Sent from my A574BL using Tapatalk
Anyone know where I can purchase these adaptors? I seem to have lost the adaptor for SRAM dub and can't find anywhere to buy in the US.
hansotto089
by hansotto089
tmanley wrote:
Tue Jan 03, 2023 1:46 am
My Rotor configuration was the following:
Axle - 30mm Standard Road
Crank - Aldhu Carbon Superlight
Spacers - Standard Road Kit (bought these just in case I needed them)
BB - Factor uses the 30mm T47 CeramicSpeed BB (Factor ships the 24mm Wheels MFG BBRight reducers/adaptors with the bike - at least it did with mine - in case you want to use something like the Dura-ace crankset)
Where did you get the "superlight" carbon cranks? Are they are new version to the normal Aldhu carbon cranks? How much lighter?
wheelsONfire
by wheelsONfire
hansotto089 wrote:
Mon Jan 09, 2023 12:41 pm
Probably Rotor USA trying to be cool!
https://rotoramerica.com/products/aldhu ... et-builder
Bikes:
Open *UP* (2016.04.14)
Erwin
by Erwin
Yes, I think they should fit. The both on the right side should be 1mm spacers, the others are bigger. As long as you don't need 0,5mm spacer you should be fine.
wheelsONfire wrote:
Mon Jan 09, 2023 4:33 pm
Already searched for the "superlight" version and found the same. :mrgreen:
There is only one Rotor Aldhu Carbon available...
pipii
by pipii
Finally finished my build after lightbicycle AR55 flyweight built with extralite spd3 arrived. 6.32kg with computer mount,pedals and one tune cage.
sworks sl8 rtp 56 5.77kg
factor ostro vam 56 6.15kg
specialized allez sprint 2023 7.13kg
retired:
Lapierre aircode 2017
specialized sl7 56 6.75kg
Co0kieMonster
by Co0kieMonster
This looks amazing, congratulations to that beautiful looking and really light Ostro!
Which hanger are you using?
hansotto089
by hansotto089
Also, what's that fancy crank setup? With powermeter?
pipii
by pipii
The crankarm is elilee xxe with xcadey powermeter. The hanger is NIUJU direct hanger for ostro, you can probably find it on aliexpress.
retired:
