I'm using Force AXS rings with no issue. Maybe I'll grab some riding video including a few front up/downshifts to capture just how smooth it is. Almost no hesitation in grabbing the next gear.
New bike: Red AXS or Dura ace di2?
Wilier Cento10AIR - SRAM Force AXS - Road/race
3T Exploro - SRAM Rival AXS XPLR - Gravel
Wilier Sestiere - Shimano Tiagra - Commuter
YouTube link: https://www.youtube.com/@JMCyclingVideos
Same here for me it works perfectly. I would suggest that you when adjusting sram stuff, look at the instructions on srams website and follow those. Don't do what you did for others.JMeinholdt wrote: ↑Wed Dec 09, 2020 8:29 pmI'm using Force AXS rings with no issue. Maybe I'll grab some riding video including a few front up/downshifts to capture just how smooth it is. Almost no hesitation in grabbing the next gear.
You know what groupset you should get? get the one you like more they are all good. if one makes you feel better than another that is the one to get.
Red AXS is heavier, expensive, less reliable. The only advantage might be it'll be easier to mount.
DA is everything better, but near the release of the new model (R9200). This means that the availability of both 9100/9200 is concerning.
Basically, AXS takes the advantage of the availability even though with not satisfying values (weight, price, reliabilities).
Reinstall the FD exactly to the procedure in the manual. If you just tamper with one screw you might not solve this. It does not have anything to do with the chainrings.gSporco wrote: ↑Wed Dec 09, 2020 7:35 pmI found once I adjusted to get the chain to stop dropping on the outside i found that it would not shift to the inside.. and then vise versu.. I couldnt get a sweet spot to get it to shift up or down without dropping.. I concluded that the ramps on the Sram AXS CR do not do a good enough job of raising or lowering the chain..
It seems that those who are not using the Sram CRs have a better shifting experience..
- 2019 Specialized Tarmac SW SL6 Red AXS Zipp 303
2019 Cervelo P3 II Red AXS 1x Zipp 808
2017 Cannondale Slate Force CX1 stock
2012 Specialized Tarmac SL2
2011 Cervelo P3 - under conversion to single speed/fixie
2009 Cannondale CAAD9 Ultegra
Done. 6 times. 3 times by myself. 3 times by three different bike shop mechanics.
Following the instructions to the letter.
No success. Now what?
You were lucky. And so where many others.
But percentage wis,e the lucky ones are in the minority.
"In my experience, there is only one motivation, and that is DESIRE.
No reason or principle contain it or stand against it........"
I'm literally 150,000% certain this is false.
If you actually think that a majority of users face failures then you have lost grip on reality.
Says who? And what "letter" do you mean? On sram.com in the support aera there is a detailed step-by-step manual.
Ive done this many many times.. Followed the manual, watched the video.. took others advise.. brought it to the shop etc.. No luck with the Force AXS and I refuse to try again after the inside chain drop left me stranded and scuffed the crap out of my new frameFeehliks wrote: ↑Thu Dec 10, 2020 6:17 pmSays who? And what "letter" do you mean? On sram.com in the support aera there is a detailed step-by-step manual.
For those that don't have these issues it's easy to say follow the manual and you shouldn't have any problems. As seen here, even skilled mechanics had to accept defeat. I wouldn't go so far as to say the majority has FD issues but they are certainly not isolated cases. Sometimes you just receive a FD that operates a bit differently compared than others...
Agreed, that sums it up..Maddie wrote: ↑Thu Dec 10, 2020 9:19 pmFor those that don't have these issues it's easy to say follow the manual and you shouldn't have any problems. As seen here, even skilled mechanics had to accept defeat. I wouldn't go so far as to say the majority has FD issues but they are certainly not isolated cases. Sometimes you just receive a FD that operates a bit differently compared than others...
or different frame's FD mounting tab or different bottom bracket alignment, or chainring spider thickness, or ... etc.Maddie wrote: ↑Thu Dec 10, 2020 9:19 pmFor those that don't have these issues it's easy to say follow the manual and you shouldn't have any problems. As seen here, even skilled mechanics had to accept defeat. I wouldn't go so far as to say the majority has FD issues but they are certainly not isolated cases. Sometimes you just receive a FD that operates a bit differently compared than others...
A great robust system will handle all those. A finicky one that only work in the right condition should be called out as such.
I've used a Shimano GRX 11 speed crank with it's +2.5mm chain line with Force AXS and had no problem, even with the big ring limit screw within a half turn of maximum. I then corrected the chain line with 2.5mm washers and it works with that chain line too. A Campy Chorus 12 crank worked great too. Doesn't seem the least bit finicky to me. I never had to do any readjustments, as long as I got the tallest teeth in the window and the marks aligned parallel with the crank. I wonder how many mechanics don't notice a FD cage moving off parallel, as the clamp bolt is given it's final tightening. Miss that and you will have problems. I first noticed this with the Campy crank, where the crank arm can touch the tail of the FD, if it's very far from parallel.
ALL the letters.Feehliks wrote: ↑Thu Dec 10, 2020 6:17 pmSays who? And what "letter" do you mean? On sram.com in the support aera there is a detailed step-by-step manual.
I had the groupset of a 18 MONTHS. Trust me. Every manual, support doc. Video. Rumor. Wisper. E-VE-RY-THING.
It is NOT for the lack of trying that I chucked my $3000 groupset in the bin.............
