New Scott foil.. at last!
Indyx
by Indyx
Bump..
Anyone seeing 2023 Foils at bike stores, or see any frameset for sale? Very interested in the black one.
Nereth
by Nereth
I pre-ordered my 2023 last year and crashed and wrote off my current bike a few weeks ago, and therefore have been getting ETA updates of the RC 10 ("black one") ever since. It's been a wild ride.
wheelsONfire
by wheelsONfire
Nereth wrote:
Mon Jan 30, 2023 2:36 am
What!!!
End of summer?
Bikes:
Open *UP* (2016.04.14)
Nereth
by Nereth
Correct. Though it's really end of Autumn, here in Western Australia. For further context, my RC10 will apparently be one of the first frames into the state (maybe country). The others are even slower.
Having said that, originally the RC10 size 58 was one of the last frames after the RC Ultimate/Pro. But everything is moving. So who knows.
ome rodriguez
by ome rodriguez
Here in Asia the RC Ultimate frameset is already available, but the Syncros integrated aero bars are October yet
mrbrown4001
by mrbrown4001
Has anyone thought about making a shim to put over the steerer to enable the use of standard cockpits?
Nereth
by Nereth
What does the steerer look like? I didn't even realise it wasn't round.
Can you not just use their stem with someone elses bar? That's the main reason I got the foil over most other aero bike options - to fit my 35cm enve handlebars.
If you deeply want to use an integrated handlebar, I guess that's more of a problem?
mrbrown4001
by mrbrown4001
Yeah I want to use an integrated cockpit but the ones Scott makes don’t go narrow enough for me
wheelsONfire
by wheelsONfire
Nereth wrote:
Thu Feb 02, 2023 1:46 am
Oh crap, i must say your patience is impressive!
Isn't Cervelo S5 a more easily accessible option?
Bikes:
Nereth
by Nereth
I run 35cm handlebars with 31.8 clamping diameter. The foil lets me use them, as did the venge disc that it is replacing. The S5 would not let me do that.
Konsi
by Konsi
Indyx wrote:
Mon Jan 30, 2023 1:43 am
Bump..
I have seen several in shop windows in Switzerland. Where are you based?
sunfire2k5
by sunfire2k5
Hi there! anybody know if it possible to use the Addict cockpit for the Foil 2023 when waiting for the new AERO cockpit..? Is the cover / spacers compatible?
FOIL 20 w/DA 9270 + ENVE 60/67 2023 wheels - GP 5000TR S 28MM
Ridley GRIFN, 105 Di2 12s + Nextie AGX45 (40mm wide) aerogravel wheels - Terra Speed 45mm
Indyx
by Indyx
sunfire2k5 wrote:
Thu Feb 09, 2023 7:55 pm
I have the same quesiton. I have a 2020 Addict RC with One piece Creston Handlebar.
I am considering buy the 23 Foil Frameset and swapping component. Curious if they work... ?
*Edit: Looks different... Bummer
https://www.youtube.com/watch?v=gZ1HfaYfyL4&t=531s
FactoryMatt
by FactoryMatt
that 1997 vintage 1" steerer design...man the swiss do some weird stuff.
also you gotta dremel the inside radius in that integrated stem. the finishing is so bad from Scott that its sharp enough to gouge hoses.
RDY
by RDY
FactoryMatt wrote:
Sun Feb 19, 2023 5:39 am
Haven't heard about many Scott fork failures lately, though there was definitely a spate 3-5 years ago. Wall thickness looks ok. But this basically means you're stuffed if you want to run a higher stack of spacers and have the safety of a longer expander - because they don't exist to fit 1" fork steerers. Plus you need the sleeve if you're going to fit a 1 1/8" stem or cockpit.
