PRO Stealth Saddles
- lord_brush
So... after some prolongued and costly experimenting last Winter, I thought I'd found "my", saddle to replace Ariones that I'd always used.
Experimented with both Stealth and SLR Superflow- both seemed good, but Stealth seemed to have slight edge.
After swapping out all x3 (turbo, and two road) ,I've noticed they seems to be chewing thru my bib shorts inner thigh. I know the Stealth is quite wide, but has anyone else encountered this? Windering whether it's back to the drawing board again! Oh, I've also started getting contact sores right on the sit-bones, but this could be down to my pretty average club/ team shorts insert rather than the saddle itself. Half-tempted to try a Romin
The right to bear arms is slightly less ludicrous than the right to arm bears. (Chris Addison)
Pretty much my experience too. Tried this and liked it a lot. But after a while started to get a recurring saddle sore. The only way I found to prevent it was to level the nose out, but then the optimum position was lost. The stealth has now joined my box of things to one day sell. Now back on Ariones too, they just work for me.
- lord_brush
Oh dear, sorry to hear you're also suffering! I bloody hate saddles! You think you've got it sussed, spend a £$££$ on decking out all your bikes with the same saddle and then.........doh!
The Arione worked for me too for about a decade, but as I got older, I found I was getting numbness, so went down exploring the cut-out route. Antares Versus Evo next? Specialized Romin? I'll probably leave it til the winter (again), to try some cheap/ used models out on the turbo and try get it sussed for next year
- lord_brush
Another one that's caught my eye is the Prologo Dimension. Looks kind of similar to the Stealth, but slightly more rounded in profile and a slighty narrower nose. Urgh, it's a mine-field
- lord_brush
Ordered a low-end Prolog Dimension, so I'll see how I get on with that for a while....
I've got a Stealth on my Gravel bike (ran on old roadie before moving over), running Spesh Power Expert on my Roadie (came with it), never noticed chewing through bibs. I find I don't notice the difference in the saddles enough to change them/the variance is kinda nice
Adding another voice recommending the Prologo Dimension. I had a very similar experience on the Pro Stealth - it felt like it was almost right, but just "not quite perfect".
Tried out a couple of the Dimension variants & have settled on one with the CPC grip pads. These seem to help keep me in place and avoid shifting around on the saddle. Does feel like I've finally found the "goldilocks" saddle for me now!
- lord_brush
142. I don't think I was sitting too far back. Could be wrong however. Yeah, it just looks like the very broad front half of the saddle has been rubbing right on the spot where the bib insert is flat-locked, as this has been eroded away. Hence why I'm hoping a similar shape......but slightly narrower nose "might", work!
It might be a matter of adjustment too. Last week I replaced the clamp bolt for a titanium version. I could have sworn that the saddle did not move a mm during the install so I did not bother to check. I went for a ride yesterday and I could.not get 100% comfortable. This morning again, not comfy like I had gotten used to. I then remembered to check the alignment and sure enough, the saddle had tilted up about 1mm. I readjusted accordingly and presto, all was well again. All it took was a fraction. It's amazing how a tiny adjustment can make such a big difference. It might be worth experimenting a bit.
- lord_brush
I thought about this and wondered how others were setting their Stealths up. I did fiddle about a bit with tilt a few weeks (ok, months maybe), as id previously had the saddle set up more horizontal across the full extent of the saddle longitudinal wise (ie taking level from tip to tail). Figured it might be wiser to nose the tip down so the flatter front half of the saddle was horizontal, rather than the full curved length. I'm not quite sure if this is coincidental with the sit bone pressure sores or not.
