2020 Aethos Sub UCI weight Specialized.
Selle Italia Carbonio SLR Boost Superflow L3 (quite a mouthful). A mega heavy 122g, but it's much more complaint than a Berk Lupina, which I love too.
The padded Lupina is not really padded, it's more of a layer of leather. The Selle Italia really has proper padding.
Cervelo P5 Disc (2021) 9.1kg
S-Works SL8 (2023) 6.3kg
- Moderator
Alpitude is a very light and surprisingly comfortable saddle for raw carbonFlatlandClimber wrote: ↑Thu Feb 24, 2022 8:48 pmSelle Italia Carbonio SLR Boost Superflow L3 (quite a mouthful). A mega heavy 122g, but it's much more complaint than a Berk Lupina, which I love too.
Allegra- Steel Lugs TBC
Aurelia- Stainless All Road 8.5kg
Bertha- TT 9.8kg
Perdita- Ti Turbo bike 8kg
Serenity- Ti Gravel 9.5kg/8.9kg
Verity- Ti Aero 8.2kg
Alya- Ti Climbing TBC
Bertha- TT 9.8kg
Do you know if the Whiskey Parts spacers are the same diameter as the s-works stem? I have to agree the diameter of the spacers provided on my Aethos Pro aretakolino wrote: ↑Sat Feb 12, 2022 1:14 amLooks like you'll have to compromise. Either you see part of the top cap shelf under the spacers or you see the top of the spacer under the stem. Is it only right under the front of the stem? That area is less visible than seeing the top of the topcap.
If you want thinner spacers, Whisky Parts carbon spacers are thinner and lighter than typical and come in both gloss and matte. I use these under 3D printed spacers for strength.
to wide for the stem, I'd also like to find something with the same diameter. Please let me know if either the ceramic speed or Whiskey are the answer, or if there is another brand anyone has found with the same diameter.
Thanks!
check out ritchy carbon oneparleez1 wrote: ↑Fri Feb 25, 2022 3:40 amDo you know if the Whiskey Parts spacers are the same diameter as the s-works stem? I have to agree the diameter of the spacers provided on my Aethos Pro aretakolino wrote: ↑Sat Feb 12, 2022 1:14 amLooks like you'll have to compromise. Either you see part of the top cap shelf under the spacers or you see the top of the spacer under the stem. Is it only right under the front of the stem? That area is less visible than seeing the top of the topcap.
Thanks!
Yeah. Mine lasted maybe a month or two. I ride on crappy, pot-ridden roads so take that as a precaution if you have similar rough roads. The seat post clamp didn’t stand a chance!FlatlandClimber wrote:I have not heard great feedback about the Yuniper now (after ordering it of course).
Probably switching back to the Tune one I have, despite it being 4g heavier.
I’m currently using this Tune double-band carbon clamp. Not sure if Tune makes this anymore.
- Factor Ostro VAM Disc
- Factor LS Disc
- Specialized Aethos Disc
- Sturdy Ti Allroad Disc
- Guru Praemio R Disc
- Factor LS Disc
Looks good, will try that out.
Paint stripping an Aethos S-Works, how bad of an idea? Found an acceptable deal, but don't like the color, bare carbon with maybe a touch of clearcoat sounds more like it. Anyone done this yet (didn't keep up with the build thread galleries as of late)? Aethos will probably retain the resale value for a while, similar to R5Ca, but what you'd expect for a custom-painted one?
Question for Aethos folks....
Regarding the front brake caliper...I'v read through as much as I could, but only found bits and pieces on using 140mm or 160mm rotors.
If using 140mm rotors...no adapter is necessary, from what I gathered.
If using 160mm rotors...a Specialized custom adapter is required.
Is that correct? Or am I missing something. TIA
- Factor LS Disc
- Factor LS Disc
The bike comes with a proprietary adapter plate for the front fork. Spacing is for a 160mm disc. For the rear, the caliper mounts directly to the chainstay. Spacing is for a 140mm disc. I think you could use a standard Shimano/SRAM adapter plate for the rear if you want 160mm on both ends.
Looks super dope! Great saddle choice
Re seatclamp: I can get a Darimo Sub4, any experience on that? I have seen the one of ROJ snap when tightening it, but his new one seemed to work.
