2020 Aethos Sub UCI weight Specialized.
I didn't think it was feasible. Has anyone built Aethos with Campagnolo?
CBA = Chronic Bike Addiction
OCD = Obsessive Cycling Disorder
Yes, you do exactly what he said above. Use a 140 rear brake caliper on the front.
The 140 rear is the Campagnolo caliper that is a conventional flat mount design, functionally the same as a Shimano or Sram.
For the juin tech cable actuated caliper the front brake is a pain the "rear"!! My friend was able to use it but had to machine the front adapter. Luckily for him he had an easy way to machine it. But I'd honestly advice against it now.Karvalo wrote: ↑Sat Jun 12, 2021 7:32 amYes, you do exactly what he said above. Use a 140 rear brake caliper on the front.
Nonetheless,the finish product is really nice: size 56 with speedplay on, Garmin mount and cages (ready to ride!) - 5.8kg
Hello,
My last build, similar as my old Ax-Lightness with Lighweight Obermayer wheels but very most confortable...
www.baron-noir.com
Specialized Aethos SUB5
Specialized Tarmac SL8 - 5.35 kgs
Specialized Tarmac SL6 - 5.16 kgs
Scott SPARK RC 900 SL SUB 8
Specialized Epic HT - 6.18 kgs
I have a friend with a very similar build but with the alpinist (heavier than those tubular) and very small parts that might be very slightly heavier at 5.8kg.
I guess I have to go and tell him to recalibrate his scale.
Yes zero offset seatpost...
www.baron-noir.com
Not trying to nitpick or anything, but it seems like your front brake pads are swapped (L>R). Might want to fix that.
'24 S-Works Tarmac SL8 RTP - soon™
'22 Tarmac SL7 Expert | Ultegra R8100 | Alpinist CL / Custom Rapide CLX 2x60
'19 Diverge E5 Comp
'18 Epic HT Comp Carbon WMN
'18 TCR Adv Pro 1 Disc
'19 Diverge E5 Comp
Very good observation, I reversed ... Thank you very much !
www.baron-noir.com
