you can't go wrong with the alpinist which is at an awesome price if you live in the ukVincentsmoox wrote: ↑Fri Apr 29, 2022 6:44 amHi
What wheelset you guys use oN aethos?
For all rounder mixing flat and hilly area
Sometimes strong wind
2020 Aethos Sub UCI weight Specialized.
Alpinist are likely to be updated soon (as the rapide CLX Tubeless are being Seen frequently in the pro tour).
The Alpinist are probably bomb proof, but not as light as Extralite or Lightbicycle, and pretty shallow and V-shaped.
Cervelo P5 Disc (2021) 9.1kg
S-Works SL8 (2023) 6.3kg
I am going to have a set of Farsports Feder 35mm hooked built up with Extralite SPD3 hubs and laced with Berd spokes. Should come in around 1080-1100g and cost about $2k less than the Extralite 339 build.
Rims just got shipped today! Hubs have been sitting in limbo somehwere for two weeks.
I know but for €1.5k the set is probably the best value for money right now. IF one lives in the UK. If I'd try to import them, there would go the value of it.FlatlandClimber wrote: ↑Fri Apr 29, 2022 9:47 amAlpinist are likely to be updated soon (as the rapide CLX Tubeless are being Seen frequently in the pro tour).
I would argue that the Farsports Feder R230 is the best value for the money.
Ultra Light Weight Tubeless: 25mm Hookless with Sapim Super Cx = 1010g for $1160. Might get lucky and get light rims and go sub 1kg
Somewhat Aero Tubeless: 35mm Hookless with Sapim Super Cx = 1090g for $1175
Clincher and Tubeless Slight Aero: 35mm hooked with Sapim Super Cx = 1130g for $1135
All sets lighter than Alpinest CLX and roughly $400-500 cheaper than the CL. 35mm version are 2mm deeper so will save you soooooo many watts.
Stans Grail CB7 with Extralite SPD3 and Berd Spokes with no issues over a year. 941g with rim tape. I have a set with Aerolites that weigh 1028g with tape. Hookless so not compatible with all tires. Expensive compared to the Feders.
Those Ultralight Feder wheels sound attractive.
Curious about the CX Supers. How are they holding up long term? How much weight do you save vs CX Rays or Aerolites? Any issues with the loose fit in the hubs? Perhaps the Farsports hubs are specially drilled for them. Triplet laced so you don't need as many spokes but center lock hubs so you add weight on the roters. What about the quality and longevity of the RD230 hubs?
I haven't gotten my set yet. Got the 55mm Feder with R230 for my Aeroad. Should come in at 1330g
I was running centerlock anyways so still going to save about 350g with just wheels and then swap in some lightweight tubes and I will probably shave a lb
If you head to the Farsports thread page it seems that there hasn't been any issues with the hubs or spokes. Savings over regular X-ray is about 20-30g
I almost went your build of Grail CB7, but it is pricey, not aero, out of stock.
So my lightweight build is the Feder 35mm hooked with Berd and Xtralite. Can run any tire, slightly aero and relatively cheap.
You could also just get a Farsports build of Feder/Extralite/cx-super and still be way cheaper than Roval and much lighter
Looking for a more lightweight handlebar/stem for my Aethos Expert, after I dial in on whether I should use 120 or 130mm stem. How are people's experiences with the Alpinist handlebar, I'm kinda sceptical to a 130mm one-piece carbon handlebar/stem? Better to go with individual components?
I dont like the tube shape, too round.andreas wrote:Looking for a more lightweight handlebar/stem for my Aethos Expert, after I dial in on whether I should use 120 or 130mm stem. How are people's experiences with the Alpinist handlebar, I'm kinda sceptical to a 130mm one-piece carbon handlebar/stem? Better to go with individual components?
Extralite stem is good enough for me
Hi,
Sizing question.
It seems I fall between a 54cm and 56cm size Aethos, as I'm 175cm.
The bikeshop advised a 56 size, as "the Aethos runs short".
I currently have a Canyon Ultimate SLX in size small, which has exactly the same stack and reach as the 54 Aethos.
As the 54cm Aethos has a steeper headangle and a shorter wheelbase, will it run more nervous than my current Canyon?
I'm not look for an even more nervous bike, but would love to check out the aethos
Any thoughts or experience?
Sizing question.
The LBS statement sounds like a typical uninformed old-school shop owner.rolfo wrote: ↑Mon May 16, 2022 2:12 pmHi,
Sizing question.
In theory, yes, steeper head angle and shorter wheelbase would lead to a snappier ride. Anecdotally, I have a friend who went from an XS Ultimate to an SL6 Disc (which in theory shares its geometry with the Aethos) and found it more nervous.
I myself don't find mine nervous at all, but I also run 30mm GP5000S which probably tame the handling a bit when compared to narrower tyres. That said, I don't think the Aethos would be something I'd define nervous at all, but I can't explain why that is the case. It surely descends better than other bikes I've owned.
Thanks! Helpfull, I was indeed affraid it would descent less stable as my Canyon (which isn't such a great descenderrobeambro wrote: ↑Mon May 16, 2022 3:22 pmThe LBS statement sounds like a typical uninformed old-school shop owner.rolfo wrote: ↑Mon May 16, 2022 2:12 pmHi,
Sizing question.
175cm and a size 56?!?! OMG!! With that height, many run a 52. Even spesh recommends 56 for people around 180cm.rolfo wrote: ↑Mon May 16, 2022 9:04 pmThanks! Helpfull, I was indeed affraid it would descent less stable as my Canyon (which isn't such a great descenderrobeambro wrote: ↑Mon May 16, 2022 3:22 pmThe LBS statement sounds like a typical uninformed old-school shop owner.rolfo wrote: ↑Mon May 16, 2022 2:12 pmHi,
Sizing question.
Yep. What @pmprego said. I am 176cm. I ride the 54cm and it is perfect for me. I can also ride a 52 comfortably. But 56cm is too big for me, feels sluggish .pmprego wrote: ↑Mon May 16, 2022 9:17 pm175cm and a size 56?!?! OMG!! With that height, many run a 52. Even spesh recommends 56 for people around 180cm.rolfo wrote: ↑Mon May 16, 2022 9:04 pmThanks! Helpfull, I was indeed affraid it would descent less stable as my Canyon (which isn't such a great descenderrobeambro wrote: ↑Mon May 16, 2022 3:22 pmThe LBS statement sounds like a typical uninformed old-school shop owner.rolfo wrote: ↑Mon May 16, 2022 2:12 pmHi,
Sizing question.
