2020 Aethos Sub UCI weight Specialized.
What defines the rumoured UCI Illegal Specialized
Doesn't Exist
75
24%
More aero than the Venge
39
12%
Lighter than the Tarmac SL6
139
44%
More aero than the Venge AND lighter than the Tarmac SL6
36
11%
Not sure
27
9%
Total votes: 316
FlatlandClimber
by FlatlandClimber
justonwo wrote:
Mon Oct 10, 2022 9:58 pm
FlatlandClimber wrote:
Mon Oct 10, 2022 10:26 am
Thanks, recovery was long and slow, but I am finally 90% well again :)
Also, really great spec on the bike. The SRM PM9 are just a lovely piece of kit.
Did you have any trouble with the chainline or 9200 FD on your PM9 implementation?
No, no noticeable effect.
Cervelo P5 Disc (2021) 9.1kg
S-Works SL8 (2023) 6.3kg
justonwo
by justonwo
Tue Oct 11, 2022 9:34 pm
Excellent. Just got the notification that the PM9 shipped. I'll install it this weekend. I'm curious how much lighter it is than the 9100 power cranks.
2020 Pinarello Dogma F12 AXS Red (Enve SES 3.4 Disc, Zipp 353)
2021 S-Works Aethos Di2 9200 (Alpinist CLX II)
2006 Cervelo Soloist
2021 S-Works Epic
Retired: 2014 S-Works Roubaix
2020 S-Works Roubaix
2020 Canyon Ultimate
2018 S-Works Camber
ViperFFM
by ViperFFM
mlosco wrote:
Tue Oct 11, 2022 3:07 pm
The future stem does not fit standard forks. It is built for the narrower steerer tubes of the spesh bikes with future shock (roubaix, and i assume also diverge).
Just found it out the hard way... interestingly, the faceplate would fit the standard stem tho. Ive identified the part number and could order jsut the faceplate but it doesnt come with the screw-fitting that holds the Garmin/Wahoo Mount. Anybody can help?
carbonLORD wrote:
Fri Mar 12, 2021 12:23 am
I'm a CAT 3 Masters racer, not a dentist.
uppis
by uppis
ViperFFM wrote:
Wed Oct 12, 2022 8:31 pm
I bought the face plate and the mount for my gravel bike with sworks sl stem, works fine. Face plate is matte and the stem is glossy but doesn't bother me. The screw-fitting should come with the mount.
ViperFFM
by ViperFFM
uppis wrote:
Fri Oct 14, 2022 5:26 pm
Thanks mate; im goona go the same route. S-Works Stem is also pretty light :thumbup:
justonwo
by justonwo
I got the SRM crankset installed. It was about 60 g lighter than my 9100 power crankset. There was a little snafu with the 9200 rings, but I think that's fixable. Weight on the Aethos without my saddle bag is 13.9 lbs.
2021 S-Works Epic
2018 S-Works Camber
mon450
by mon450
Another pic from yesterdays ride
Enviado desde mi iPhone utilizando Tapatalk Pro
Cuypmeister
by Cuypmeister
mon450 wrote:
Sun Oct 23, 2022 7:18 am
Where did you buy the decals?:)
Cuypmeister
by Cuypmeister
Found via Insta / Specialized Switzerland website the new colours for 2023 of the Aethos S-Works! Especially, the S-Works decals on the downtube make it 100% finished!
Anybody suggestions where to buy these decals in Europe?
Cuypmeister
by Cuypmeister
mon450 wrote:
Sun Nov 20, 2022 3:21 pm
https://vinilosbici.com/
GRACIAS
HHH
by HHH
morrisond
by morrisond
Does anyone know where I can find an 58Cm Aethos 10R (I need Mechanical) frameset in Carbon Satin Flake Silver that they will ship to Canada?
Thanks
MeekMouse
by MeekMouse
Anyone know where it's possible to order the front brake flat mount adapter for the Aethos (Specialized Part # S200700001)? The only online shop I can find is in Italy and does not ship to the US.
It's the final piece missing on my build, but unfortunately out of stock at all the local shops that I've reached out to.
kode54
by kode54
I had the same issue. I ordered one through the LBS but they never came through. So I got a bit creative and used a standard Shimano one and slotted it enough to give me a bit of lateral play. Worked better than expected.
- Factor Ostro VAM Disc
- Factor LS Disc
- Specialized Aethos Disc
- Sturdy Ti Allroad Disc
- Guru Praemio R Disc
