But 680grs for a repainted frame is still pretty good. I take that.
2020 Aethos Sub UCI weight Specialized.
- alexneumuller
- Contact:
So after handing a 1kg weight on it, it showed 820grs. I take from that that my scale is defective. Now the question arises how to recalibrate it.
The bike still looks great, your builds always have the best custom paint jobs. I started lurking in ww from following the custom green Supersix you built up. To be honest I am bit disappointed that the scale is defective and the paint didn't have anti gravity properties .alexneumuller wrote: ↑Fri May 07, 2021 2:07 pmSo after handing a 1kg weight on it, it showed 820grs. I take from that that my scale is defective. Now the question arises how to recalibrate it.
How is the SuperSix nowadays? Interested to here your thoughts comparing vs the Aethos once its built up.
Where do you get the value of 680g.alexneumuller wrote: ↑Fri May 07, 2021 2:07 pmSo after handing a 1kg weight on it, it showed 820grs. I take from that that my scale is defective. Now the question arises how to recalibrate it.
If for 1kg mass you read 820 grams this mean the scale indicates 82% of real value.
Therefore, if your scale reads 500g for the frame, real weight is 500/0.82 = 610g.
A very good weight given the complexity of the paint scheme.
- alexneumuller
- Contact:
Depending really on how serious I take each gram and especially taking under consideration that I failed my Math GCSE (English School Exam at Age16).maquisard wrote:Where do you get the value of 680g.alexneumuller wrote: ↑Fri May 07, 2021 2:07 pmSo after handing a 1kg weight on it, it showed 820grs. I take from that that my scale is defective. Now the question arises how to recalibrate it.
I have ordered a new scale. But will only arrive by time bike is build.
I m taking the Aethos, either the SL7 or Super Six Evo with me to near Nice this summer. I will be a frequent visitor to the Service Course there. A whole month of cycling. now the question that arises is which third bike should I take, as my bike rack can take three.
I'd take the new up. I bet there are nice gravel paths tooalexneumuller wrote: ↑Fri May 07, 2021 4:09 pmDepending really on how serious I take each gram and especially taking under consideration that I failed my Math GCSE (English School Exam at Age16).maquisard wrote:Where do you get the value of 680g.alexneumuller wrote: ↑Fri May 07, 2021 2:07 pmSo after handing a 1kg weight on it, it showed 820grs. I take from that that my scale is defective. Now the question arises how to recalibrate it.
2018 Specialized Tarmac Expert
- alexneumuller
- Contact:
So build is finished…..but not complete. 6.6kg in a Size 56. And yes it could be lighter with Dura Ace Di2 current generation. Still have a THM Crankset on order, so that should cut the weight a little.
- alexneumuller
- Contact:
I have not measured it, but I generally ride around 826mm saddle height from BB. And yes it looks little funny, as the seat tube length is relative short, and shorter than on the SL7. I can measure the exact BB to Saddle Top tomorrow. But it fits perfectly, and had a bike fit and adjustment. The Stem length is 120mm.
Sure I could ride a Size 58 and it would look more normal. However then I would have to ride a 100mm stem or a 90mm stem, and I dont like the feeling of short stems. Also the stack would be to high. Custom geometry bikes fit me better......but I like Specialized, and I can make them work.
Curious what your body measurements are. You sound similar to me with long legs, and I'm wondering how I'd do on a 56, or you on a 58. I ride a 58 with 815mm from BB to saddle, but I also use a 120mm stem. The reach on the 58 is only 7mm longer, so I doubt you would have to go down to anything less than a 110mm stem. And you'd be able to slam your stem and probably go with a -17. But, I guess with the Aethos it's all about weight, so it would be heavier.alexneumuller wrote: ↑Wed May 12, 2021 8:07 pmI have not measured it, but I generally ride around 826mm saddle height from BB. And yes it looks little funny, as the seat tube length is relative short, and shorter than on the SL7. I can measure the exact BB to Saddle Top tomorrow. But it fits perfectly, and had a bike fit and adjustment. The Stem length is 120mm.
Specialized Tarmac SL7
Specialized Crux
Velobuild 168
Trek Checkpoint ALR
Specialized Crux
Velobuild 168
Trek Checkpoint ALR
As much as I admire the weight of the Aethos, the sloping top tube and ridiculously long seatpost results in an odd looking bike in larger sizes.
Agreed, it has awesome weight specs, but its not a good looking bike at allSeedster wrote:As much as I admire the weight of the Aethos, the sloping top tube and ridiculously long seatpost results in an odd looking bike in larger sizes.
So, what you seem to be saying is that if a rider has unusual proportions, then a bike looks...........unusual? The Aethos itself seems to have unremarkable geometry as far as I can tell.
I have noticed the ridiculously long seatpost on smaller sizes as well.
