manystyles
by manystyles on Fri Jan 07, 2022 9:11 pm
GZAmk2 wrote:If you want an easy life, avoid Hope calipers. Lots for sale second hand…
I hear less complaints people who use these calipers with Shimano, but yeah, they have been and still are a pain.
Turrifik
by Turrifik on Sat Jan 08, 2022 3:39 am
tjvirden wrote:Turrifik wrote: ↑Sun Jan 02, 2022 7:55 pm
Thanks to the wealth of information here, I bit the bullet and built an Aethos Expert frame up this summer with Ultegra Di2. Have been loving it for local hill climbs.
Currently sits at 6.62kg ........
This is really nice - I'm not convinced that all the Aethos frame sizes look in proportion, but this does. 54 or 52?
It’s a 54. 400x100 front end. Fits well so far.
Thanks for the tips guys. Ordered XTR rotors and 9270 DA calipers. Will leave shifters alone. Not sure about crank+PM upgrades. Too many options.
*EDIT: shoot. Front 9270 DA calipers don’t seem to be in stock anywhere….
Turrifik
by Turrifik on Sun Jan 09, 2022 4:23 am
ryanw wrote:Front and rear callipers are identical, you just need to use the proprietary Aethos front mount.
Much appreciated Ryan. I spent a bunch of time comparing photos and trying to confirm this. Sometime proprietary parts pay off. Order updated.
Cheers
Now to figure out a good crank+PM option.
Is DA 9100 with dual 4iiii PM still a concern for driveside PM accuracy? Either way, this doesn’t seem like a big improvement over Ultegra.
Beancouter
by Beancouter on Sun Jan 09, 2022 2:11 pm
Turrifik wrote:ryanw wrote:Front and rear callipers are identical, you just need to use the proprietary Aethos front mount.
Cheers
I went Sram Red Dub for my current Aethos Build. I have a Stone 5 arm spider coming which (if it fits, which there is a ? Over) with extralite chainrings will bring it in at about 490g.
Have sanded down to avoid the Shimano mismatch..
If that all works, it will go to _4iiii for a factory install of a left side podium. All in should be 500g
Turrifik
by Turrifik on Fri Jan 14, 2022 4:02 am
I’m having a hard time finding DA 9100 cranks in stock locally. Can anybody point me to a good source? Preferably in 50/34, 170mm flavor.
I’ve been tempted to try a used crankset off ebay, but it’s not easy to judge tooth wear etc in most photos. This is a good example:
EDIT: can’t post an ebay link it seems.
On a positive note, finally tested a C59 saddle for a few hours on the trainer. Better than expect. Will see if it’s a keeper.
Beancouter
by Beancouter on Sun Jan 16, 2022 5:47 pm
Turrifik wrote:Sounds promising. Let us know how it works out. Very interested.
499g; +10g for the 4iiii.
Need to build the bike up now and see how the crank works out on the road. I think the more traditional look works well with the frame
bennito
by bennito on Mon Jan 17, 2022 8:42 am
Turrifik wrote: ↑Sat Jan 08, 2022 3:39 am
[/quote]
Is it possible to install 9270 disc brake caliper with 9170 shifter ?
Does look possible on the shimano compatibility listing
https://productinfo.shimano.com/#/com?c ... acid=C-499
Any advice ?
Cheers
milanv
by milanv on Mon Jan 17, 2022 12:35 pm
bennito wrote: ↑Mon Jan 17, 2022 8:42 am
Any advice ?
Cheers
[/quote]
Yes, you can see that it is fully compatible.
K4m1k4z3
by K4m1k4z3 on Wed Jan 19, 2022 8:54 am
andreas wrote: ↑Wed Jan 19, 2022 12:17 am
Anyone know the stock weight of the Aethos Expert 2022 model (C38 wheels, Ultegra Di2 12 speed, alu cockpit). I'm guessing around 7.2-7.4kg in size 56?
The pine green one is 7.115 kg in 54.
'24 S-Works Tarmac SL8 RTP - soon™
'22 Tarmac SL7 Expert | Ultegra R8100 | Alpinist CL / Custom Rapide CLX 2x60
'19 Diverge E5 Comp
'18 Epic HT Comp Carbon WMN
'18 TCR Adv Pro 1 Disc
andreas
by andreas on Wed Jan 19, 2022 12:18 pm
Thanks, so an upgrade to Alpinist bars or similar (-150g) and selling the wheels to replace with something lighter in equal price range (-100g ish) should bring it down to the 6.9kg mark, excluding pedals, for a ~$500 added cost.
It's a pity that the standalone price of the frameset is so high, I'd prefer the Tropical Teal color, but not at a ~$1500 premium compared to the price + wheelset resale value of the Expert complete build.
ryanw
- in the industry
