Garmin Connect down - Ransomware?
Timmy269
by Timmy269
I have tried the cable of the garmin of my wife an that doesn't work either. When I connect the garmin to the pc, the garmin starts up en the battery loads. I turn the garmin off an the Battery is still loading but no connecting.
I know I can choose that the device storage to the sd card, I thought I had configured that, but no
mrlobber
by mrlobber
Timmy269 wrote:
Mon Jul 27, 2020 8:31 am
I have a garmin edge 1000 which always sychronisezed with my smartphone using garmin connect and strava sychronized with strava. Cause the problems with Garmin connect since friday i wanted to upload my ride from yesterday to strava tu connect the garmin edge to the pc. The only thing is uploading the battery, the usb device not recognized. I used several cables and tried, with my desktop, laptop, desktop at work, nothing. I'm almost sure it's a problem with the garmin edge. the stupid thing also is that de activities are saved on the edge's harddisk and not in the sd card.
In addition to the important thing people mentioned earlier - the cable must be also allowing data transfer, not charging only - it might as well be that your micro usb cables are partially damaged (and this is really easy to happen especially if they're being used frequently). Recently, one of my cables died (for no apparent reason) and I realized that out of other 6 I had all over the house, none worked properly (they still charged the mobiles, but not on "quick charging" mode).
Retired bikes: Cervelo S5 2015 / Felt AR FRD 2014 / Cannondale SS HM 2014 / Scott Addict SL 2014 / Scott Plasma Premium 2014 / Orbea Orca 2008 / Look 596 /
Timmy269
by Timmy269
When I have a wrong cable, do I still get a message on the pc that the usb device not is recognized.
It seems we are getting back to normality.
Timmy269
by Timmy269
just bought a new data cable, works fine with my smartphone, but with my garmin is still keep the message on the pc that te usb device not is recognized en goes in uploading the battery.
the guy in the store said that Garmin has a special micro usb?
Unniti
by Unniti
It's not USB anymore if it can't use normal USB cables. It might also be that the connector on the device is broken on the data pins.
Timmy269
by Timmy269
Unniti wrote:
Mon Jul 27, 2020 11:48 am
Is there a data connector in the garmin edgee 1000 and a connector to load the battery?
sychen
by sychen
kgt wrote:It seems we are getting back to normality.
Slowly.. Looks like they are metering the returning services to avoid ddosing themselves..
I've seen better and much worse responses to this sort of attack... Assuming they didn't pay ransom.
Sent from my Pixel 4 XL using Tapatalk
bikeboy1tr
by bikeboy1tr
Timmy269 wrote:
Mon Jul 27, 2020 12:38 pm
Its more than likely your PC that is not seeing the Garmin device not a cable or a Garmin issue. I have two laptops and one always sees the Garmin and the other one only sees the Garmin sometimes. It could be a driver issue on your PC. Try to plug your Garmin into another PC and if it sees the Garmin than you know its your PC at fault.
Back to the issue at hand this morning my wife was able to load five training sessions to Garmin Connect.
viewtopic.php?f=10&t=154188
2018 Colnago V2R Rim Brake
2012 Time RXRS Ulteam Rim Brake
2008 Time VXR Rim Brake
Timmy269
by Timmy269
tleo wrote:
Sat Jul 25, 2020 9:15 pm
miltmaster3 wrote:
Sat Jul 25, 2020 8:42 pm
I am the only lucky person that have over 6 years TP as a buck up ! Wow
I've got all my .fit files saved locally and backed up on my computer. In Garmin Connect you can have them email you your complete history which I've done a few times just in case something like this would happen and heaven forbid there was a data loss. But hopefully they can restore everything without any loss. Plus, my Edge 830 has like the last 9 months of activities saved in its memory to bridge the gap between when I last did the Garmin download and today.
Where can I ask to email me all my fit files?
sychen
by sychen
Sometimes try another usb port on the same computer. They aren't all specced the same.
spdntrxi
by spdntrxi
The above is true... also I find some longer USB cords dont work for me. The original garmin cord always works for me.
pdlpsher1
by pdlpsher1
Yeah. My PC sometimes sees it and other times doesn't. Try a different port or just unplug/replug until it sees it.
Sent from my KFMAWI using Tapatalk
VanGosroth
by VanGosroth
jlok wrote:
Mon Jul 27, 2020 8:20 am
https://connect.garmin.com/status/
Garmin Connect features are gradually back online.
I hope they were able to fix this themselves and not pay money to thieving scumbags.
2020 Specialized Roubaix - 3.697345734 kg
2021 Specialized Tarmac - 18.58434534 kg
202X Firefly Road Bike - 0.0kg
adamhenry
by adamhenry
USB hubs also cause problems for some devices.
