Ridley Noah Fast experiences
- seamaster76
- Contact:
Hope this helps.
- seamaster76
- Contact:
Handlebar’s weight is related to 42*100
- seamaster76
- Contact:
Thanks!Cycomanic wrote:That is such a great looking bike!
Amazing thanks. Do you know the actual frame weight too?
- seamaster76
- Contact:
Yes, with all the bearings approx 1.300grams in size MMilese wrote:Amazing thanks. Do you know the actual frame weight too?
- seamaster76
- Contact:
Sorry 42*110seamaster76 wrote:Handlebar’s weight is related to 42*100
Thanks again.
So frame + bottom bracket? + headset? = 1300g? Does that mean the frame is around 1150g?
I had a reply from a shop earlier advising forks 440 and frame 1000g for disc frame in small.
Compared to Focus Izalco Max @ forks 358g and frame 890g it isnt all that light, but looks amazing.
Neither have good availability and no discounts.
- seamaster76
- Contact:
Based on my experience, it should be correct.Milese wrote: So frame + bottom bracket? + headset? = 1300g? Does that mean the frame is around 1150g?
somewhat reviving an old thread, but hey better than creating a new one right?
I have just bought a noah fast disc and am about to embark on building it up with record 12 speed mechanical. anyone have any experience with cabling one of these up with mechanical cables, it sure looks like it will be tight around the handlebar area but super clean install once finished.
On the weight side of things here are the weights of the framest parts, this is for size small:
Frame 1030g (with hanger and bottle cage bolts)
Fork 481g (completely uncut)
seatpost 179g (including rail clamp)
Handlebar 401g (100mm stem 400mm bar)
Hi,
I got one and built with dura ace di2 so can't answer your cabling query directly, but recently read that someone fitted a full 105 rim brake groupset cable groupset and said it was surprising easy and works well.
My di2 / disc build routing was surprisingly easy.
Here are my weights....
Sent from my SM-G960F using Tapatalk
did you measure each of the component weight?
7kg is very light.
7kg is very light.
Milese wrote: ↑Thu Apr 08, 2021 10:51 pmHi,
I have a new di2 ultegra bike with enve 65 wheels and with 28mm pro one (addix) and light tubes iam at 7.9kg. Rotor aldhu incl powermeter. Frameweight in the prizmatic paint size M is 1140gram.
Very very clean setup with the cockpit. Love the looks and feel of the handlebar. I have the 110/400. Measures 38/40cm. Short reach with 75mm also feels great.
FOIL 20 w/DA 9270 + ENVE 60/67 2023 wheels - GP 5000TR S 28MM
Ridley GRIFN, 105 Di2 12s + Nextie AGX45 (40mm wide) aerogravel wheels - Terra Speed 45mm
Yes, as in the table I shared. I weighed them, I didn't make them up.jackie wrote:did you measure each of the component weight?
7kg is very light.
The complete bike shows as 7.0kg on my luggage scales so matches the individual part list.
