My adventures in chain waxing: goals, reviews, suggestions...
Mocs123
by Mocs123
You don't even have to do that, just drop it into melted wax. Any old wax will melt at that point.
2015 Wilier Zero.7 Rim - 6.37kg
2020 Trek Emonda SLR-7 Disc - 6.86kg
2023 Specialized SL7 - 7.18kg
Torbjorn
by Torbjorn
I'm sure this has been answered many times already, but do you first drop it into a pot of any old random wax to remove any contamination before you drop it into the main wax pot?
Eterna7m
by Eterna7m
No, boiling water does that.
basilic
by basilic
For best results, start with a new chain, strip of factory lubricants, then wax. Even if you didn't wash it with boiling water between waxes, the chain will keep what feels like forever (>>15000 km). Rinsing with hot water before waxing may improve on that (I don't bother).
If the chain has been used, lubed with oil, it's contaminated inside the rollers, and you'll never get that out. It'll work fine with wax, but won't last as long.
man1ac
by man1ac
Is there some decent guide on waxing I could follow? Wanna try it coming from wet lubes.
Have the Ultrasonic Cleaner anyway and just ordered some MSW.
I'd start with my Ultegra chain (approx 5000km on it. No wear measurable), clean it with the ultra sonic and chain cleaner.
Then a fine acetone bath to get everything out, then bathing in hot wax..
What I don't get:
After waxing I'll run the chain for like 200-300km (only nice weather) and then I need to do it all over again?
Torbjorn
by Torbjorn
Eterna7m wrote:
Thu Mar 23, 2023 11:26 am
The guy above us literally just said not to use boiling water. Hence my question on how you get rid of the "contaminated" wax.
Erlandal
by Erlandal
Torbjorn wrote:
Thu Mar 23, 2023 1:33 pm
If you just rode in really filthy conditions, you can pour boiling water onto your chain in order to prevent bringing too much shit into your wax bath.
Otherwise, you can just drop your chain in the bath and be on your way.
matcav
by matcav
man1ac wrote:
Thu Mar 23, 2023 12:44 pm
in good weather conditions, my chain usually stands good for 4/500km - shorter if it's wet/dirty rides.
then yes, I usually take it out, and install another one (I have two chains rotating on the same drivetrain) already prepared. If both did their turn, I put them in a container with boiling water, rinse them a couple of times, dry, and go for another wax bath
man1ac
by man1ac
matcav wrote:
Thu Mar 23, 2023 4:24 pm
Thank you! So you dont relube with any wet-wax lube "on the fly"?
uppis
by uppis
What I don't get:
https://moltenspeedwax.com/pages/clean-your-chain That step is easier with ufo clean, they also have guide for ultrasonic cleaner but no experience with that
https://moltenspeedwax.com/pages/waxing-your-chain
https://zerofrictioncycling.com.au goes really deep with waxes as well
slijkplaat
by slijkplaat
what do you people do when you have a wet ride ?
i always read that you have to rewax , but also after a 20km short community ride ?
TobinHatesYou
by TobinHatesYou
slijkplaat wrote:
Fri Mar 24, 2023 6:47 am
Top it up with a drip wax. UFO Drip, Silca Super Secret, etc.
kode54
by kode54
I carry a small squeeze bottle with me on wet days of the Silca one and only use it when needed to avoid hearing a chirpy chain. I also learned many years back that on a hard pack dusty dirt ride, my freshly waxed chain didn’t last as long ((70+ mi) and I was squeaking on the way home. So I take the same small one ounce bottle on those rides as well. Whe I say dusty, I mean that powdery dust that gets everywhere, even inside the frame as I noticed some when changing BB bearings out a year later.
- Factor Ostro VAM Disc
- Factor LS Disc
- Specialized Aethos Disc
- Sturdy Ti Allroad Disc
- Guru Praemio R Disc
rolfo
by rolfo
Sorrry, but I couldn't find the answers in the post...
I had my Silca wax overheated to 140 degrees (left the crackpot on high..). Is this wax still usable or did it lose it function?
And I drive Sram AXS (force and red) chains but the drivetrain seems pretty loud when the the wax has broken in.
Same experience here? I use the Silca secret drip the fill the chain up, but rolls of as the chain is still waxed. So it doesn't seem the chain is the "raw"at that point.
Also on my "Tacx" set up which even come outside ;-)
Any info would be helpfull, thanks!
HansZuDemFranz
by HansZuDemFranz
rolfo wrote:
Fri Mar 24, 2023 12:43 pm
Cant help you with the first question, but regarding the noise, I had the same issue when running Sram AXS waxed. In my experience a Red cassette helps dramatically with the noise.
