My adventures in chain waxing: goals, reviews, suggestions...
Mocs123
by Mocs123
What are people's thoughts on Josh's meathod of hot dip wax every 1,000 miles (1,600km) with a drop of Super Secret per roller ever 125 miles (200km). I had been using MSW and re-waxing every 250 miles (400km) but just bought some Super Secret to try and quieten things up.
2015 Wilier Zero.7 Rim - 6.37kg
2020 Trek Emonda SLR-7 Disc - 6.86kg
2023 Specialized SL7 - 7.18kg
eins4eins
by eins4eins
I'm doing something similar. MSW hot dip and then relubing with CS UFO.
I have 6 chains in circulation and with this method i only need to hot dip every other month or so.
maxim809
Administrator
by maxim809
Hi collective ww.
What are alternative chemicals for stripping a chain if you live in a small apartment without a garage, balcony, or open area?
Spirits/Turp bath followed by Acetone/De-alcohol works great for places with lots of ventilation and a place to store safely.
Looking for something good enough for the apartment. Used chemicals is indoor safe for storage before disposal, and does a good enough job to strip factory grease.
Lakal
by Lakal
maxim809 wrote:
Sat Jun 04, 2022 4:53 pm
Hi collective ww.
Ceramicspeed Ufo Clean: https://zerofrictioncycling.com.au/wp-c ... ise-v2.pdf
maxim809
Administrator
by maxim809
ty ty
C36
by C36
ricerocket wrote:
Mocs123 wrote:
Wed May 25, 2022 6:55 pm
PaulH wrote:
Wed May 25, 2022 5:15 pm
Would an ultrasonic cleaner be as good as the chemical solvents before waxing ?
Not in my experiance. An Ultrasonic cleaner is a great additional step, but not a replacement for solvents.
You're allowed to use solvents in your ultrasonic cleaner... :)
To clean a greased component you need both, solvent and mechanical action. The US cleaner only gives you mechanical action by vibrating the liquid. And the solvent breaks the lubricant molecules.
MrRolandos wrote:Been using MSW without any issue, get about 300-400 from a wax, just the noise after 200km is :( , so I bought Silca's Super Secret chain lube, batch #3. Chain wiped completely dry, shaked bottle for like 2-3 mins but its so thin, it just falls straight of the chain on the ground. The chain is completely dry and clean. After spilling alot on the ground, I managed to cover the chain in lube. Is this normal and do you guys experience similar things? What can I do to improve/change this?
This pic is from the 3rd series (according to R2 store at least) SSS, 2’ after I put a drop on each roller. Over the entire chain I had a single droplet that went to the floor and that was done at a rather hot temp (28degC).
The only thing particular I may do is shaking the bottle till I see no darker deposit (the fancy additives) on the bottle walls (and that takes… a lot of time… a solid 5’).
carmody
by carmody
kervelo wrote:
Wed May 25, 2022 6:31 am
takolino wrote:
Tue May 24, 2022 10:20 pm
@Kervelo, can you wax the chain without further cleaning after using dynamic chain cleaner? ...
Yes, I have waxed the chain without further cleaning. The Dynamic Cleaner may leave a protective film, but the chain does not feel oily or anything like that. Disclaimer: I use the Dynamic Speed Potion Wax (https://dynamicbikecare.com/product/speed-potion-wax/), so perhaps the cleaner and wax are made to match. I have not tried any other wax, so I cannot tell if they are any different.
How's is your expirience with Speed Potion?
kervelo
by kervelo
carmody wrote:
Sun Jun 05, 2022 8:42 pm
So far the experience has been very positive. The chain feels very smooth and silent. I have used Speed Potion on three chains so far - my road bike, gravel bike and XC mountain bike - but have ridden only on road due to the miserable weather we have had here. I am not yet able to tell how long the chain can be used before re-waxing.
Edit: the Unbound winner used the Speed Potion wax, so I believe it should work offroad too.
MrRolandos
by MrRolandos
Strange, this is a MSW waxed chain and now rewaxed with Silca's? I got the same batch from R2. Did you apply in cross chain? Big big? Yeah the shaking needs to be really good i've noticed, my chain is due for a top off so I guess ill try that one.
C36
by C36
This is Silca Supersecret topping a chain waxed with Silca 230km ago. I didn’t really bother crossing the chain, here I was on small/big, and I haven’t really seen it causing problems when you “massage” the rollers.
usr
by usr
Mocs123 wrote:
Tue May 31, 2022 1:26 pm
For me (as a "dripper") this raises the question of how much worse the drip part alone could possibly be.
I'd guess that it's mostly about goals: is your main motivation low chain wear? Drip alone should be fine. Do you try to achieve the highest imagined ZFC scores (or real ZFC scores, if you happen to run that test setup)? Frequent immersion would probably be best, but slightly less frequent immersion with drip top-ups might be a way to achieve similar results with slightly lower total maintenance effort. Would you love to go all in on immersion, but you can't stand hearing any drivetrain noises and immersion doesn't stay silent for long enough? Adding some drip might make the difference.
MrRolandos
by MrRolandos
C36 wrote:
Mon Jun 06, 2022 12:42 pm
So I did everything again, shake bottle, seems normal, no problems.
The stuff that comes out is closer to milk, on your pictures it looks grey. My stuff is just white, as soon as I drop a drip on a roller, poof, it just falls straight off. I guess the only difference is that you waxed with silca and i waxed with MSW.
I also took a different approach, chain off the bike to prevent mess everywhere, and wax it while its off the bike. More control, but no. Same stuff, room temperature, shaked about 5-10mins. Some rollers it stays, most just falls off.
Kinda dont wanna waste this product, but I guess I might need to go Ceramicspeed drip if that works...
Mocs123
by Mocs123
I've recently been topping off my MSW with SSS mine is also very milky and the first time I did it I had about six drops hit the garage floor, but yesterday was able to get one drop on each roller without spilling any. I've been doing maybe ten to fifteen roller at a time and then working it into the rollers with my fingers before moving the crank to bring up a new bit of chain.
Mine is also white and milky, similar to a thin elmers glue. My bottle is green with a different (newer??) label. - No idea if there is any difference in the product itself.
My first application went on a chain that had been immersed in MSW about 100 miles (161km)earlier but had started to get noisy (raspy) and the SSS did quieten it up quite a bit for the next 125 miles (201km) until I re-applied. So far I'm pretty happy other than this stuff isn't cheap.
MrRolandos
by MrRolandos
Right right, yeah the SSS is pretty expensive for what it is, so it needs to work. Not completely satistief, if it's done. I'll give CS a go, did anyone clean a chain with CS UFO yet and what are the results compared to the normal cleaning method?
Lakal
by Lakal
Lakal wrote:
Sat May 28, 2022 9:14 am
I just stripped an YBN chain with the UFO Cleaner.
100ml, 5 minutes soaking, shake the bottle for a minute and then rinse with water.
Used a hair dryer for 5 minutes.
The chain seems to be perfectly clean.
I gave 22 dollars (150DKK) for the bottle.
My experience, MrRolandos.
