2021 BMC Teammachine
tunaseng
by tunaseng
Just placed an order with my local dealer on the 2023 Bmc teammachine slr01 in white/red. Going to migrate the group set over from my giant tcr advanced pro.
I am hoping this is a huge upgrade considering the frame set for the tcr is only $1.8K vs SLR01 at $7.2k.
I just found out the junction for my 11s di2 cannot be placed in the bar end anymore. Which junction box should i be getting in this case?
As for bike comp mount, any reccomendations that would work with the integrated cockpit?
Thanks in advance.
ODC
by ODC
tunaseng wrote:
Wed Aug 10, 2022 3:01 pm
Thanks in advance.
The junction box on the SLR01 comes into the frame just at the bottle cage.
tunaseng
by tunaseng
ODC wrote:
Wed Aug 10, 2022 5:11 pm
Thanks in advance.
Can I know what part should I be getting? Not sure if it's junction B or something.
Mocs123
by Mocs123
extrusionedwin wrote:
Sat Apr 23, 2022 2:26 am
timemachine special color
1. prologo scratch M5
2. Favero look
3. Hyper 50 + tubolito
4. Dura ace 12S 50/34T-30T
total weigth 7.26kgs
of course if replace to carbon saddle, use dura ace powermeter and dura ace pedal, with hyper 38 , I believe is under 7.0kgs
Beautiful bike! I love the color!!
2015 Wilier Zero.7 Rim - 6.37kg
2020 Trek Emonda SLR-7 Disc - 6.86kg
ODC
by ODC
tunaseng wrote:
Wed Aug 10, 2022 5:45 pm
Thanks in advance.
Normally the EW-RS910 junction box is the same for installation for in the handlebar as of in the frame.
MichaelK
by MichaelK
You'll need 2 Junction Bs and the EW-RS910.
https://www.bmc-switzerland.com/media/d ... _final.pdf
(page 29-30)
lemos
by lemos
I just weighted my BMC SLR01 FOUR 2020 (di2 ultegra, disk) using my bathroom scale. The most scientific method of all!
(without head unit and bottles)
  • all stock size 51
  • close the Gap hideMyBell Garmin mount
  • Grand Prix 5000 (I can't remember the tubes)
  • dura ace k7 I had from my previous build
  • assioma, one-sided power meter
8kg dead.
(just realized this thread is for 2020. well, you can do comparisons anyway)
tunaseng
by tunaseng
Just got my 2023 TM slr01.
Set up as follow:
Ultegra di2 11s, 165mm crank 50-34, cassette 11-28, xtr discs rotors, favero assioma Shi power meter, sworks power saddle, farsports revo 48mm, gp5k STR tan walls, exposure lights front and back, stock bottle cages, wahoo bolt2 on stock out front mount on ics 90/400 bar.
Weighing in at 7.3kg with all accessories.
Any suggestions to reduce weight or recommendations to change the out front mount?
Thanks @michaelK and @ODC for the replies on di2 junction box installations.
frankmueller
by frankmueller
Here is mine, 2020 TeamMachine SLR, Size 51cm
7,350 Kg
Dura Ace with Powermeter
Weight
Weight
Bike
Bike
check6
by check6
Thanks in advance.
I use this and like it. Added a QR attachment for my light (Night Rider 850).
https://k-edge.com/shop/computer-mounts ... mbo-mount/
tunaseng
by tunaseng
check6 wrote:
Mon Aug 22, 2022 7:58 pm
Thanks in advance.
Did it sit flush under the bar? Incidentally the link u provided says not compatible with bmc ics. You are really pushing it there 😂
check6
by check6
tunaseng wrote:
Wed Aug 24, 2022 4:02 pm
Thanks in advance.
It is flush and I might not have used the link to the correct model. That or K-Edge has changed/no longer makes the compatible one. I'll take a close look.
cunn1n9
by cunn1n9
Thanks in advance.
Did it sit flush under the bar? Incidentally the link u provided says not compatible with bmc ics. You are really pushing it there Image
I use the same kedge mount on my bmc slr01 one piece carbon bars. I used some washers to make it fit properly. Have a Garmin edge 1030 and a light mounted and it’s solid. Reason I am not using the original mount is that with the Garmin and light it was too heavy and the mount broke.
tyro13
by tyro13
Hi guys,
My computer mount from my ics cockpit broke off yesterday are there alternatives that are stronger than the original?
My handlebar is the one piece cockpit from a slr01.
Greetings from Belgium
stannymenza
by stannymenza
I really really like the Close the Gap hidemybell, I think this one fits the ICS: https://www.closethegap.cc/product/hide ... aceday-fi/
