2021 BMC Teammachine
Cemmac
by Cemmac
I'm looking to get BMC SLR One 2022 as i like black design. Not really into BMC bikes, is this endurance type and SLR01 is race bike?
slake21
by slake21
Cemmac wrote:
Wed Mar 30, 2022 10:55 pm
SLR01 is the highest tier of teammachine bikes, the others without the 01 are lower tier. Main difference is the lack of integrated cockpit and a slightly heavier frameset.
The endurance type for BMC are the roadmachines models.
check6
by check6
You're looking to get one, but you not really in to BMC? I think I married your sister :wink:
ivonenand
by ivonenand
Hi Guys,
I may have a change to get a Teammachine SLR 01 frameset; I don't have a groupset for it yet, but I'm hoping I'll be able to get Ui2 or Force in spring time. Anyways, I do have a question regarding the Teammachine's fork steerer tube. I've seen that the steerer tube is not round, but rather rectangular and slim. I understand this was done to allow the cable routing from the handlebar down to the frame. But, does anyone experience any problems with sideplay or flex because of it, especially in the left/right direction? From the images, the tube does seem quite narrow.
Thanks for any input,
Ivo
slake21
by slake21
ivonenand wrote:
Fri Apr 01, 2022 8:32 am
Hi Guys,
Ivo
The steerer is round where needs to be. Inside the stem shims make it round so you can tighten the stem and above the fork blades it's still round.
Image Image
Cemmac
by Cemmac
I could get used Izalco Max 2019 Dura Ace di2 with low weight
https://www.focus-bikes.com/int/izalco- ... award-2019
Or rather pay for new BMC Teammachine SLR
https://www.bmc-switzerland.com/intl_en ... gory/1918/
Can't decide, but as performace i think i could be faster with Focus
tyro13
by tyro13
Anybody knows the seatpost of a slr01 2019-2020 is the same shape of the slr01 2022?
I have a slr01 2022 with seatpost setback 15mm and i want a seatpost with zero setback!
Thx in advance
card0s
by card0s
ODC wrote:
Mon Aug 16, 2021 10:44 am
Changed my S-works Tarmac SL7 for this beautiful BMC SLR01 with full Campagnolo spec. Was a totally build up.
Some bike specs:
- Frameset: BMC SLR01 size 58 in the team colors
- Handlebar: BMC ICS carbon team handlebar 140mm length and 40mm width
- Saddle: Fizik Antares R1 carbon wide version
- Groupset: Campagnolo Super Record
- Wheels: Campagnolo Bora Ultra WTO 45mm
- Powermeter: power2max campagnolo
- Pedals: Shimano dura ace (I know Shimano combined with Campagnolo is not done but I love Shimano pedals)
- Computer: Wahoo Element Bolt V2
- Weight: still need to do this!
Some measurements:
- Saddle height (center bottom bracket-top saddle): 81.5cm
- Saddle setback (center bottom bracket- tip saddle): 9cm
- Reach (tip saddle-middle handlebar): 64cm
- Drop: +-13cm
Congrats on this beautiful machine :D
Did you manage to weigh it?
Jonolsson
by Jonolsson
tyro13 wrote:Anybody knows the seatpost of a slr01 2019-2020 is the same shape of the slr01 2022?
Thx in advance
It's different
extrusionedwin
by extrusionedwin
timemachine special color
1. prologo scratch M5
2. Favero look
3. Hyper 50 + tubolito
4. Dura ace 12S 50/34T-30T
total weigth 7.26kgs
of course if replace to carbon saddle, use dura ace powermeter and dura ace pedal, with hyper 38 , I believe is under 7.0kgs
card0s
by card0s
extrusionedwin wrote:
Sat Apr 23, 2022 2:26 am
2. Favero look
Really good-looking bike.
That is my favorite color scheme from their lineup along with the team white frameset :D
arizawa
by arizawa
It's a bit of a long shot but does anyone happen to have an SLR01 fork from a 2021 or 2022 BMC Teammachine? It could be new, or even off off a damaged frame set or frame warranty and sprayed to match the frame.
ivonenand
by ivonenand
Hey Guys,
I've noticed that the Teammachine SLR01 decalls are actually stickers and not paint; there's three of them, on the heat tube, down tube and one just behind the seatpost area. Does anyone have any problems with the stickers comming off after a while of use? I cannot imagine those stickers being very durable, especially considering that the bike can get cleaned ofter and the cleaning rag will rub into the sticker edges.
Any experiences?
IVo
tifh21
by tifh21
For the lower tier version (2-7) any light carbon stem and handlebars recommended and saddle? Will be enjoying my bike first but I want to make it lighter in the future (already changed the wheelset). Anyway, thanks!
panuelos
by panuelos
Hello, i am wondering if its possible to remove the spacers below the stem or they must be there ? Its the Integrated carbon stem (ICS).
