Wow! So nice! Can I know your height and inseam for the size 54 selection? I am 174cm with 82cm inseam and I am doubting a lot between sizes 51 and 54, there a big gap between them in my opinion, and I am in just in the middle of both.
2021 BMC Teammachine
Can I know your height and inseam for the size 51 selection? How many many spacers (width) did you finally place in there? I am 174cm with 82cm inseam and I am doubting a lot between sizes 51 and 54, there a big gap between them in my opinion, and I am in just in the middle of both.dexe wrote: ↑Sat Oct 17, 2020 9:49 amI picked up my slr01 four yesterday and it's not quite clear to me wether I can placers above the stem. I believe it's not possible, but then I did get a round spacer with the bike and some alternative insert (part 10) Did anyone find the ics2 assembly manual? It's not yet on the bmc website it seems.
I already found the manual. It's in the same manual as for the bike itself. It's indeed possible to put a chimney on top with the alternative topcap and insert.
For those who are interested, my bike weighted 7.4 in size 51, so a bit over spec. It's probably possible to save some weight with the wheels (24f/28r). Also I read somewhere the bars would be less wide than advertised, but mine are slightly over 42. I'll probably swap them for 38 at some point.
Does anyone have the SLR Two version (ultegra di2), the silver one? I am wondering if the claimed weight of 7,69 kg is trustworthy. And I mean the bike with the bottle cages in place.
And actually, I was told it is possible to have fully integrated cables routing in SLR version. You just have to replace the fork and stem with the SLR01 version. I'm not deliberating if the investment if worth it.
I just saw some question wrt. to weight in the thread...
This one is size 51, and the weight is 7,1 with DuraAce Di2/Disk (incl. Powermeter), DA Pedals and an Ergon Carbon saddle. Wheels are Cosmic SL with Conti GP5000 , DA 11-28 and Tubolito innertubes.
Congratulations, i have the same bike with same weight with enve 3.4. Wanted to put it Darimo seatpost to save 100gr.frankmueller wrote:I got the new TM beginning of December, very nice ride.
I switched from my Colnago C59 and went for a Dura Ace setup.
Weight is 7,1 kg, I guess with tubulars i will get below 7kg, however this is with Di2 and disc brakes.
How do you compare it with colnago?
@ Pukutis
The TM is more aero and feels stiffer I guess due to the thruaxle vs. skeewer wheels on the C59.
is there a D-shaped Darimo seatpost which fits the BMC?
Yes!! You save around 100gr. See below mine. Very happy with it.frankmueller wrote:@ Pukutis
so your seatpost is Darimo? how did you secure the battery inside it?
No, mine is still the bmc. I am after the Darimo. Next upgrade.slake21 wrote:so your seatpost is Darimo? how did you secure the battery inside it?
Built this last week.
7.4kg as pictured.
7.4kg as pictured.
IG: RhinosWorkshop
IG: RhinosWorkshop
- MrCurrieinahurry
- Moderator
Very nice!
- jdecraene85
Finally some real-world pictures of builds, I have been looking for some time for real pictures, but they're hard to find so far.
Could anyone maybe measure if it would be at all possible to fit Enve 3.4 AR Disc with Schwalbe Pro One 28 mm? That would help me a lot in some decision making...
What size is the one in your picture Ryan? Thanks. Surprised it's heavier than the other two on this page despite the ICS cockpit, maybe due to crankset, chainrings and OSPW?
