Pro Vibe Carbon stem
I have a pro vibe carbon stem + pro vibe aero superlight handlebar. I use a rec-mounts garmin mount. Works well
https://mobile.twitter.com/RECMOUNTS/st ... 44/photo/1
Just to "yes and" the posts above -- the usual K-Edge mount will not work on the Vibe aero bars (I nearly lost a fingertip trying to make it work). They sell a very specific mount for these bars only, but I'm sad to hear those don't sit straight!
I don't have the bike anymore and the stem/bars and just sitting in my basement but IIRC I believe you're right, that mount (which is the one I had) was specifically for the older bar/stem combo.
Looks like this new bar/stem combo would need a new specific mount.
- wheelsONfire
Bikes:
Open *UP* (2016.04.14)
Computer mount aside, how is the stem compared to other you´ve ridden guys?
I like the cool look and ´aeroness´ of it, but need stiff stem for sprints at the same time. Almost no reviews anywhere.
- robbosmans
- Moderator
- Contact:
I found these mounts on ali, they seem to be the exact same mounts that ccache sells. This way you will be able to mount your head unit straight and centre so everyone can sleep at night
Pro Vibe ALU
Pro Vibe Carbon
Pro Vibe ALU
Pro Vibe Carbon
No angle adjustment. Despite the stem offered in different angles?
So, if you have -10 degree Pro Vibe Alloy stem, the computer mount will raise up by 10 degree and with -17 degree Pro Vibe Alloy stem, computer mount will be parallel to the ground?
https://pt.aliexpress.com/item/10050022 ... 52445qvmcQ
I´ve bought the mount for the Pro vibe stem, from this store, and is just perfect
can you post pic of the mount on the carbon stem. is the computer level on slanted?
mariosimas wrote: ↑Mon Apr 12, 2021 9:28 pmhttps://pt.aliexpress.com/item/10050022 ... 52445qvmcQ
Current Rides:
2023 Tarmac SL7 Di2 9270
ex 2019 S-works SL6
ex 2018 Trek Madone SLR Disc
ex 2016 Giant TCRAdvanced Sl
ex 2012 Trek Madone7
ex 2019 S-works SL6
