wheelsONfire
by wheelsONfire on Sat Jul 18, 2020 1:30 pm
To me this chart is a bit strange.
If i would go for a 50/37 and 11-28 cassette instead if 10 cog, i would be riding near same as now.
50/36 and 11-28. A 34 chainring is too small IMO.
Bikes:
Open *UP* (2016.04.14)
DaveS
by DaveS on Sat Jul 18, 2020 3:02 pm
A 50/36 is an oddball combination. Most who use a compact crank usually want as much range as possible, so the standard offering is always 50/34. That's what SRAM compares their standard offerings to.
Following their example, to get more range at both ends, you would need a 48/35 and 10-33 to get more range at both ends. A 10-28 cassette would produce a nearly identical lowest gear.
It still seems to show that SRAM has no confidence in their front shifting working with more than a 13 tooth difference.
FWIW, one of my Campy Chorus 12 bikes is now using a 48/32 crank with a SRAM 10-36 to get a top gear that's like a 53/11 and low gear of 32/36. Compared to my previous Campy 11-34 cassette, I have more top gear and more low gear, but it's only because I have a 16T difference at the crank.
DaveS on Sat Jul 18, 2020 4:26 pm, edited 1 time in total.
Nickldn
by Nickldn on Sat Jul 18, 2020 10:02 pm
tigradekat wrote: ↑Sat Jul 18, 2020 3:56 pm
Pretty devastating poll results so far.
I wonder what a poll on 11s Etap Red would look like. Plenty more experience with that group now.
Giant Propel Advanced SL Red Etap 11s Easton EC90 wheels CeramicSpeed BB Zipp SL70 bars 6.5kg
Vitus ZX1 CRS Campy Chorus 12s Bora WTO 45 disk brake wheels Zipp SL70 bars 7.5kg
SL8 build with Craft CS5060 Wheels in progress
Georgegibson
- Location: Wallstrasse 28, Hessen, 35321, Laubach, Germany
by Georgegibson on Mon Aug 17, 2020 9:20 pm
MayhemSWE wrote: ↑Tue Jun 16, 2020 8:32 am
I had random chain drops when first setting the system up early last season. Chain would drop from big ring down to the small or beyond when the chain was in the middle of the cassette and just riding along. Managed to get rid of it by some very careful tuning of the front derailleur.
This year it started doing it again. I figured maybe the front derailleur had gotten out of its very picky alignment, but eventually noticed my chain had somehow broken in two places. Also not sure if it was just an optical illusion but my front chainrings appeared just a hair wobbly, which may have been what caused the broken chain. Popping off the crank required almost no effort so I may have failed to tighten it enough initially.
Did you find out why the chain tore? you tuned it before, has this anything to do with it? I am facing the same issue too and was reading this article
https://papasroadtrip.com/how-to-tighten-a-bike-chain/ to find out a solution. I was planning to do what the author told here, but now after reading your complication - I am worried if I do something such to my chain unintentionally.
motorthings
by motorthings on Mon Aug 17, 2020 9:37 pm
Has anyone been able to find the SRAM Front Derailleur Setup tool (12-SPD) tool anywhere?
My FD is working great, but i'd love to have one of these tools on hand next time I need it.
justonwo
by justonwo on Thu Oct 08, 2020 7:05 pm
Well, after 1,200 miles on my Pinarello, the Red RD failed. The pivots on the parallelogram developed a bunch of play and the RD kept jumping out of gear when I would hit bumps. To summarize by SRAM Red AXS experience:
1) The RD on my Roubaix had to be replaced after about 600 miles. It developed the same gear-jumping problem and slop as on my Pinarello.
2) The FD on all three of my AXS Red-equipped bikes had a lot of chain dropping problems and had to be tweaked many times by various techs to make it reliable.
3) The chainrings on my Canyon developed a wobble after about 200 miles and the entire crankset had to be replaced.
This experience is quite surprising given how reliable SRAM's mountain bike groupsets are. I doubt I will ever buy another SRAM road set.
2020 F12 AXS Red (Zipp 353)
2021 S-Works Aethos Di2 9200 (Alpinist CLX II)
2006 Cervelo Soloist
2021 S-Works Epic
2024 Topstone Lab71 (Force/XX1, Terra CLX II)
Retired: 2014 and 2020 S-Works Roubaix
2020 Canyon Ultimate
2018 S-Works Camber
justonwo
by justonwo on Wed May 12, 2021 9:16 pm
Anyone else had any chain dropping issues with SRAM Red 12 speed on the FD? I continue to have drops every 5-6 rides or so. I have yet to have the FD adjusted with SRAM's FD fixture. I'm wondering if anyone else has had luck with that?
2021 S-Works Epic
2018 S-Works Camber
DaveS
by DaveS on Wed May 12, 2021 10:25 pm
I suspect that adjustment problems and chain drops can be traced to the marks on the cage not being parallel to the chain rings. Quite often, the FD rotates during the final tightening of the clamp bolt. I align the marks carefully, then carefully measure the gap between the crank arm and the tail of the cage. After final tightening, I check it again. Small gaps can be measured with feeler gages and larger ones with drill bit shanks. I've done many setups and never had a chain drop. I don't use sram cranks.
justonwo
by justonwo on Thu May 13, 2021 12:08 am
DaveS wrote: ↑Wed May 12, 2021 10:25 pm
In my case, the marks are absolutely parallel to the chainrings. That marking may not be sufficient for positioning, however, because SRAM released this positioning tool. I guess I should probably get ahold of one and try it.
2021 S-Works Epic
2018 S-Works Camber
DaveS
by DaveS on Thu May 13, 2021 12:21 am
The positioning tool won't stop unwanted FD rotation and may not make it obvious that it has occurred. I've setup the FD 7 times with no problem and no special tool.
justonwo
by justonwo on Thu May 13, 2021 2:38 am
DaveS wrote: ↑Thu May 13, 2021 12:21 am
Like I said, the cage has marks are dead nuts on top of the chainring. The cage is aligned exactly the SRAM's specs.
2021 S-Works Epic
2018 S-Works Camber
OnTheRivet
by OnTheRivet on Thu May 13, 2021 5:22 am
nycebo wrote: ↑Wed Jun 17, 2020 3:41 am
TobinHatesYou wrote: ↑Tue Jun 16, 2020 3:08 am
I almost hate the FD setup issues enough to switch off eTap to Di2. If Di2 had true eTap shift logic, I would switch in a heartbeat.
But my friend, Di2 can be programed to do so using shimano e-tube software. Indeed I like that setup even better than SRAM because I use the big buttons for the rear mech and the little buttons for the front mech. Left lever shifts inboard and right lever shifts outboard.
Gotta give SRAM great credit for defining that incredibly intuitive shift logic, though.
Hahaha, I did this to match it to the way my axs shifts on my gravel bike. Thought I was the only one.
MyM3Coupe
by MyM3Coupe on Thu May 13, 2021 6:19 am
ipenguinking wrote: ↑Sat Jul 18, 2020 9:37 pm
I wonder why Sram just can't get front shifting right?
It's not called "SCAM" for no reason. Their components are total garbage. Always been garbage since the early days of "twist shift." Expensive trash, but trash none the less.
