dmgdroid
by dmgdroid on Thu Jun 18, 2020 2:06 pm
akaspin wrote: ↑Thu Jun 18, 2020 5:55 am
I used Red AXS group for about eight months. Switched from Shimano DA Di2.
1. Front deraileur works good even under load but requires insanely precise installation. I used laser level for alignment. Ordered AXS FD tool.
Can you tell me where you ordered it? So far I've only found
this shop that is selling it (pre-order for shipment in July); but it is listed as for 50-52 teeth chainring – is it really size-specific? I'm thinking to get one to fine tune my FD with 48/35 rings.
Shrike
by Shrike on Thu Jun 18, 2020 2:11 pm
Oh nice, thanks! So if I mix it up a bit, the 35 front with a 33 rear will maybe give me something like a 34/31? Or would it be even less you think?
dierckxsens
by dierckxsens on Thu Jun 18, 2020 2:35 pm
SRAM Force AXS owner for 1y+, problems with FD almost solved w chain catcher from Canyon. No chain noise issues like some others users. Main problem is that the brakes engage too late, risk of fingers stuck behind the shift tabs, quite a scary feeling when it happens. All sorts of ajustment and bleed tried w/o any significant effect, problem also reported by other users on this (great) forum.
Will revert to fishing wheel at next buy.
Cheers
andychampionsound
by andychampionsound on Thu Jun 18, 2020 9:15 pm
Shrike wrote: ↑Thu Jun 18, 2020 12:08 pm
TobinHatesYou wrote: ↑Thu Jun 18, 2020 12:04 pm
48/35x10-33t is what you want.
Saved me a ton of time, cheers!
The Force set on my TCR advancedSL is 48/35 with a 10/28 cassette and the ratios are brilliant. I moved from a DA9000 group with 53/39 x 11/28 which I've been riding for the last 4 or 5 years and I much prefer the AXS set-up. It matches or exceeds the outer ratios of the DA, but it has much better gear steps and i've found it much easier to find the right ratio. particularly climbing in 35x19. that gearing is almost transcendent! And then there are the steps up to 21/24/28 but i'm using that end of the cassette a lot less than I was on the DA given the chainrings.
akaspin
by akaspin on Thu Jun 18, 2020 9:36 pm
dmgdroid wrote: ↑Thu Jun 18, 2020 2:06 pm
Yep. Ordered there. 50-52 mentioned as largest chainring. So the tool is universal.
dmgdroid
by dmgdroid on Thu Jun 18, 2020 11:31 pm
akaspin wrote: ↑Thu Jun 18, 2020 9:36 pm
Wicked, thanks akaspin! Hopefully the estimated shipping dates won't get delayed (SRAM's production seemd to be hit pretty hard by the pandemic due to lack of raw materials; I ordered a chainset in March and was told the delivery was delayed to July)
senseless
by senseless on Fri Jun 19, 2020 4:43 am
1400km on my Red AXS. No drop chain whatsoever. Works perfectly fine. Only complain is the connection with SRAM mobile apps is not good, but that's just an occasional check on updates.
Before this was on R8070 DI2, I would say Red's shifting is as good as DI2, but prefer the left/right click and it's quieter compared to my Di2.
I guess LBS mechanics plays a big part in the setup, glad that my regular mechanics is quite experience handling SRAM.
young
by young on Sun Jun 21, 2020 9:00 am
looks like a set for people who really don't want to mess with hydro brakes. rim brake shifters with mechanical disc calipers.....no thanks
N0Klu3
by N0Klu3 on Sun Jun 21, 2020 11:17 am
Besides my first ride when I just got the bike and tried to put power down through a stop street and snapped my chain, mine has been flawless.
Basically I had a weak link from the factory and it wasn't even the connector link it was just a random link in the chain.
Replaced chain and its amazing since
carbonazza
by carbonazza on Mon Jun 22, 2020 11:36 pm
I'm again with this here. It is probably too alien for most, but a 46x10-50 is worth some consideration.
I just did a particularly long ride this weekend with it, and definitely consider to take it for my next trip to the Alps this summer.
A 48x10-52 could be the perfect one.
justonwo
by justonwo on Sun Jul 05, 2020 2:55 am
Still having issues on my Canyon. I need to take my bikes over to the LBS with SRAM's new FD tool. If that doesn't solve my problems, I'll probably push SRAM to give me my money back on those drivetrains.
2020 F12 AXS Red (Zipp 353)
2021 S-Works Aethos Di2 9200 (Alpinist CLX II)
2006 Cervelo Soloist
2021 S-Works Epic
2024 Topstone Lab71 (Force/XX1, Terra CLX II)
Retired: 2014 and 2020 S-Works Roubaix
2020 Canyon Ultimate
2018 S-Works Camber
woodyvalentine
by woodyvalentine on Sat Jul 18, 2020 4:37 am
Have full red AXS except cassette. It's okay. I like the levers and looks. Rear shifting is okay. Lately have been getting some missed/weird/double shifts going to easier gears. One thing I found was noise/creaks from the Force cassette was solved by taking it off and re-greasing the XDR threads/freehub body. Front derailleur is a pain to set up. Needs to be 100% correct. I've got it to a reasonable point. I had about 5-10 chain drops in and out. Now it's okay and no drops but it's a little slow and I'm cautious. I had 2 11 speed red ETAP Groupsets as well. Found the shifting a smidge better there. I think this chain is really stiff. I'm also getting a lot of rotor rub on the front from a combo of a very very slightly out of true front rotor and a little bit of fork flex and sticky piston. The sticky piston is likely the bigger culprit. I have lubed the piston with fluid and pushed in/out with blocks as per manual. But still sticky/lazy. Have the dub spindle and power meter and those are fine. With it was removable spider. Wish the force cassette wasn't coated black. Also the cassette prices are steep. Stock centreline AXS 6 bolt rotors are also tough to keep true in my case.
