New Giant TCR Advanced announced
- JOwenSmith
Anyone know what length caliper mounting bolts are used in the rear position? I am attempting to order all of my parts while the frame stays packed up in the box.
Thanks in advance.
Thanks in advance.
You can try with a spiral wrap like this one from the link. it does not look as neat as shrink wrap but beats the look of electrical tape.
https://www.bike24.com/p2459243.html
- JOwenSmith
Can anyone provide insight into the cable management on a Advanced Pro Disc with mechanical? This is my first internally cabled bike that actually has guide tubes, so i'm unfamiliar with the Giant's process. Any and all input would be appreciated as I would like to get this built up, and this is the last item before I pull it all together.
- Do you leave the guide tubes in place through the frame?
- Do you run the tubes through the guide under the bottom bracket shell?
- Do you pull the guide tube through the cable port to the front deraileur?
- JOwenSmith
Can find this on AliExpress
Thanks for sharing. Will give that a shot.IvanZg wrote: ↑Thu Dec 16, 2021 12:53 pmYou can try with a spiral wrap like this one from the link. it does not look as neat as shrink wrap but beats the look of electrical tape.
Just back from a 30 mile ride and I think I can get away without chopping the mast at all. Saddle is at the very upper limit for me, but I am not bouncing around, rocking at the hips, nor have excessive reaching from the ankles. I will cut the fork down a bit though once I get it dialled in.
I would never pick this colour but there's no choice so will just embrace it and go for a completely non steathy look.
Think it would look great with these bad boys!
- JOwenSmith
I'm in a similar situation. After having a lot of black/grey bikes, i am building up a chameleon galaxy frame. I guess i'll Oil Slick all the things.
Chameleon Galaxy is a great colour, though, and I much prefer it to Astral Aura, although that's growing on me now I'm stuck with it. I've got a Supacaz oil slick saddle on the way and I'm going to try to get hold of those EEs. Might even get oil slick spokes and go full Miami Vice.
