New Giant TCR Advanced announced
GT8
by GT8
Can anyone tell me if I can use Shimano 'inner' centre lock rotors fit with the 2022 TCR axles please?
'Outer' lock ring versions are out of stock and I prefer the inner tool as well.
stjepan
by stjepan
Can anyone confirm if the following handlebar has any restrictions in mounting on the Giant TCR: https://r2-bike.com/SYNCROS-Stem-Handle ... -mm-110-mm
I'm not looking for a (sketchy) integration, just like the shape of the bars (loved them on my Scott Foil previously).
EDIT: I have an OD fork.
AlexWCS
by AlexWCS
bedampft wrote:
Wed Dec 28, 2022 6:13 pm
TCR Advanced SL Team
7,1kg as in the photos. (Pedals, Computer & Mount, Bottle Cadges and Tool Box)
Size M/L, Seat height 760mm
Dropbar is a Newmen Wingbar Advanced 318 in 400mm that I'm trying out for the first time. Not light (220g), but the shape is quite nice.
Question regarding the tyres please. I see you have the Schwalbe Pro One TLEs fitted and they are listed as a compatible tyre by Giant for the SL1 rim in 25C, 28C and 32C. What diameter tyre do you have and did you/your mechanic have any difficulties fitting them?
bedampft
by bedampft
AlexWCS wrote:
Wed Feb 01, 2023 10:18 am
I've been using 25mm for abot 2 years now and they actually measure 27mm on the SLR 1 36 Disc. I would say they need the right amount of force to get them on. Not to much and not to little (to feel uncomfortable).
AlexWCS
by AlexWCS
Many thanks. No issues with the tubeless fit/seal either?
bedampft
by bedampft
AlexWCS wrote:
Fri Feb 03, 2023 10:42 am
Nope. Always worked like a charm.
Even with having the tires sliced open from broken beer bottles last summer, and being forced to put tubes in them, they seated themselfs immediately.
jasjas
by jasjas
bedampft wrote:
Thu Jan 05, 2023 11:14 am
Thanks!
From starting where the bend to the seatmast ends it's 225mm.
That is a fantastic looking bike....
DouglasDDX
by DouglasDDX
Great looking bike!
Can I ask you how much setback you have and the length of your saddle since its almost all the way towards the front?
I have the possibility to make a deal on a new TCR in M/L and have a similar seat height (765-770mm) and 60mm setback with 250mm saddle. Which can be difficult to acheive on some bikes or weird looking.
samarskyrider
by samarskyrider
In case anyone is interested, I've received a TCR Advanced Pro frameset size Large (L). Below are measured weights:
- frame + hanger + bottle cage screws = 1087gr
- uncut fork = 380gr
- seatpost = 190gr
- headset bearings = 39gr
- expander plug = 39gr
- front axle = 54gr
- rear axle = 47gr
- Contact SL 130mm stem = 166gr
eric01
by eric01
That is a pretty frame! Giant seems to be stepping it up with paint jobs too.
athletic91
by athletic91
Would like to check from model 2022 onwards, the TCR advance vs advance pro is that the frame is exactly the same carbon grade, but that the pro fork is OD2, the non pro fork is also full carbon but normal 1 1/8 steerer?
Im considering getting a non pro version as i prefer the standard steerer but am concern if its of a much lower carbon grade
bedampft
by bedampft
DouglasDDX wrote:
Mon Feb 06, 2023 10:50 am
Great looking bike!
Thanks!
Setback is 80mm, lengh of saddle is 240mm. Got 5mm left to the max forward position.
DouglasDDX
by DouglasDDX
Thanks bedampft!
andyh27
by andyh27
Just took delivery for my first TCR. 2023 Advanced Pro in Orion Nebula M/L.
Hoping for a weight around 7.5kg without pedals. Spec sheet
bmrk
by bmrk
andyh27 wrote:
Wed Feb 22, 2023 12:44 pm
Are those frame weights confirmed by you?
