Luescher lost for words: Cervelo S5 head tube damage
TheDoctor
by TheDoctor
Over to you, Hambini:
https://youtu.be/yajCXeNTbqk
I don't own a bike like that but would be shocked if I did.
Just taking the front wheel out and putting it in the back of your car with the bars turned seems like a bad idea, let alone crashing it or hitting the handlebars.
Seems an obvious design f#ck up, any thoughts?
Specialized S-Works Tarmac SL6 Disc
Cervelo R5 Disc
Argon 18 Nitrogen
Argon 18 Gallium
Canyon Exceed CF SLX 8.0
Felt Decree 1
Maddie
by Maddie
Unbelievable. That's a 4k frame! Shout out to Raoul and Hambini for their expertise and not holding back
spdntrxi
by spdntrxi
even my circa 2014 BMC Timemachine has the little bump stops to prevent this....
Stoffa
by Stoffa
I think this video by Luescher has the potential to destroy Cervelo as a brand, and well deserved.
velov
by velov
Are most bike brands just using first year engineering interns?
hambini
by hambini
It says Damon Rinard all over it.
Hambini Aeronautical Engineer, Polluting YouTube since 2016 - views expressed are my own...
Broady
by Broady
Jesus, who signed that off.
Even a little rubber block pushed into each side of the internal piece would be better than nothing.
Noctiluxx
by Noctiluxx
Wow, just wow!
2018 Bianchi Oltre XR4, (Celeste Matt)
2018 De Rosa SK Pininfarina (Blu)
2019 Trek Madone SLR (Rage Red)
2019 Giant TCR Advanced SL (Chameleon Blue)
2019 Cervelo R5 Disk (Team Sunweb)
2019 Giant Revolt Advanced 0
AJS914
by AJS914
I always hated the look of that frame anway!
I love the work that Luescher does but I got the gist of the issue in 3 minutes.
Js2
by Js2
Speechless....
Kayrehn
by Kayrehn
"I could do a Hambini sort of..... erm.... But that's not my style, but I can see why..."
TobinHatesYou
by TobinHatesYou
Rinard hasn’t worked at Cervelo in a long time. Not sure why his name would be brought up.
The new Madone has a similar issue with fork crown / HT interference. There is a steerer stop under the headset bearing cover, but it is plastic or a composite that breaks easily. The cam design in the S5 does seem even worse.
lewishong9
by lewishong9
My 2019 S5 disc must have some sort of Pin in the frame. It actually stops the bar before it hits the down tube.
Wonder why Cervelo stopped for 2020.
edit: nevermind mine is also shit :)
TobinHatesYou
by TobinHatesYou
lewishong9 wrote:
Fri Feb 28, 2020 1:54 am
I might assume nothing has changed and in those two examples the pin was broken accidentally or whoever assembled the bike forgot to install it.
E: #ornot
glepore
by glepore
hambini wrote:
Thu Feb 27, 2020 11:33 pm
You might want to check to see when Damon went to Cannondale vs the new s5. Might be slanderous.
Cysco Ti custom Campy SR mechanical (6.9);Berk custom (5.6); Serotta Ottrott(6.8) ; Anvil Custom steel Etap;1996 Colnago Technos Record
