Questions for 3t Strada 1x Frame
Pauly1st
by Pauly1st
Hi,
The short 3T Strada seatpost is with its 239g on the heavy side to be political correct. Anyone knows a lighter option, carving off 100g?
And has anyone found a direct mount solution for the 3T Starda frame or can support with a 3D drawing?
Thanks and happy riding
C36
by C36
Darimo has a seatpost for the frame on the pipeline... but no firm launch date
Pauly1st
by Pauly1st
Thanks for the heads up!
SandwichNP
by SandwichNP
Does anybody know if there's any reason I can't cut the seatpost that I have? I didn't realize there were multiple sizes and the one I have is too long. I need to shave about 2" off mine.
Regarding the OP, I'd be interested too...I haven't even finished building mine and I hate the seatpost head on this. Would gladly buy another one with a micro adjust top.
LewisK
by LewisK
I'm not familiar with the frame/seatpost, but virtually all posts can be cut. Just make sure there is a minimum of 8cm of post left in the frame after you've cut.
saverin
by saverin
LewisK wrote:
Mon Feb 24, 2020 4:11 pm
or better yet, translate the existing 'minimum seatpost insertion' length to the cut seatpost length to be even safer.
SandwichNP
by SandwichNP
That's what I would do- maybe throw a black sharpie line 2" up from the min insertion after I cut 2" off. I just found it surprising that they offer multiple lengths for what I thought was a pretty standard procedure- make a big post, cut off what you don't need.
Speedman
by Speedman
Can the METRON 5D ACR integrated can match with the 3T Strada frame ?
I looking for Token Cable Box system too... Any idea about matching ?
SandwichNP
by SandwichNP
Speedman wrote:
Sat Feb 29, 2020 9:09 pm
No but also maybe yes. The head tube is very narrow at the top for the strada. The cables exit behind the headtube and wrap around. I can't imagine any way to route a cable by the stem/upper headset. That doesn't mean you couldn't use the vision metron system, but I can't see how you could route cables in the headtube.
Personally, I like the "semi-integrated" design. It gives me a little more freedom to change things up/modify when needed, but not have to disassemble and fully reassemble each time. The ultra-aero bikes are awesome, but I like that I can swap my stem on the strada without bleeding brakes and buying new hoses.
Speedman
by Speedman
SandwichNP wrote:
Sat Feb 29, 2020 10:47 pm
I think it is possible I allow to bend a little the cable to make an internal routing. I can't see how I couldn't route cables in the headtube...
And personnaly, I'm crazy about the clean style of all integrated aero bike.
