Reassembled my bike but now left with 2 spare bits!!!
CaudaEquina
by CaudaEquina
Retard here,
Can someone identify where these 2 bits come from? They seem to work together
My bike is a 2018 endurance cf 8 with Ultegra 8000 disc full groupset and krysium elite ust wheels
I’ve only took out the entire drive train and the rear disc nothing else for a deep clean.
It’s driving me mad, been looking at exploded views of my conponents and frame but can locate where these 2 bits come from...
Many thanks
Butcher
by Butcher
Auto mechanics just throw those parts in their tool box or garbage.
joejack951
by joejack951
Can you give some sense of scale to the parts? How long are they, outer diameter? It is hard to tell from a picture with nothing else in it whether they are 5mm or 25mm.
Miller
by Miller
What exactly did you disassemble?
Miller
by Miller
Gavin929
by Gavin929
that is the end cap to your mavic wheelset. looks like the drive side cap by the freehub body.
CaudaEquina
by CaudaEquina
Gavin> thought so too but my wheels appeared complete and there’s no issue fitting them on the frame
Millers> Front crank except bottom bracket, rear dérailleur, cassette, chain, rear disc.
Joejack> the diameter corresponds to the thru axle they are 1-2cm in max dimension
And they were definitely in the bike since I’ve put everything I took apart in a single box and there’s mud and dirt on them.
Note that the bike is completely rebuilt and looks fine and feels solid, No play, weird noise or anything, haven’t ridden it because of that tho
alcatraz
by alcatraz
Plastic makes me think it can't be drivetrain related but are they parts from a freehub assembly? Check the freehub operation and wiggle the cassette and check for play sideways maybe. It should feel solid and spin smooth.
Did you touch the headset?
CaudaEquina
by CaudaEquina
Also worth mentioning that I know the square route of JackSh#t when it comes to cycles.
Took me the whole weekend to refit, set up and adjust the front and rear derailleur
CaudaEquina
by CaudaEquina
From outside my wheels look exactly like what I see on Mavic website
https://shop.mavic.com/en-gb/ksyrium-el ... r0973.html
alcatraz
by alcatraz
What size are these parts? Put something common and small next to them for reference.
Could they be parts of a tool you used?
wheelbuilder
by wheelbuilder
Bizarre. The silver one certainly does look like a hub end-cap, but the black one looks like a conical washer used on post mount disc brakes. This would be two totally unrelated parts..............and no post mount conical washer is the same diameter as a hub end cap.
joejack951
by joejack951
CaudaEquina wrote:
Mon Feb 10, 2020 4:58 am
Well that’s a quick release hub and you mentioned that you have thru axles so either that picture doesn’t really match your hub or you need to get your eyes checked :-)
Take some pics of both hubs with the wheels removed. I’ll bet you’ll find your answer (perhaps with some help from the forum).
alcatraz
by alcatraz
joejack951 wrote:
Mon Feb 10, 2020 6:08 am
...either that picture doesn’t really match your hub or you need to get your eyes checked :-)
:twinkle:
CaudaEquina
by CaudaEquina
20200210_221559.jpg[/attachmen] [attachment=1]20200210_221608.jpg
Help!!!!
