CeramicSpeed OSPW touches cassette
Ritsuke
by Ritsuke
Hello,
I have a problem with my OSPW as it touches my cassette.
Setup: CeramicSpeed OSPW, 11-28, 52-36, Dura Ace 9000 Di2, S-Works Tarmac SL5
Every combination works except the 28. My OSPW upper pulley touches the sprocket. The B-tension screw is maxed out so that couldn't be it. Do I need another derailleur hanger (which one?) or another solutions?
Thanks!
S-Works Tarmac SL5
Retired: Specialized Allez Sprint Red Hook Crit
RECAR77
by RECAR77
The one with the two 17t pulleys has a capacity of 28t
53-39=14
28-14=14
11+14=25
The one with 13/19t pulleys has a 32t capacity which is the one you need
Sent from my moto g(6) using Tapatalk
Attermann
by Attermann
the 17/17 version is for 6800 and 9000
the 13/19 is for 8000 and 9100
that's at least the way i understand it.
RECAR77
by RECAR77
Attermann wrote:the 17/17 version is for 6800 and 9000
Ah, yeah my bad
OP, have you put the p-axle in the hole in the cage that results in the most tension?
Ritsuke
by Ritsuke
Correct, I have the 17/17 version for 9000 so that should be good.
I have put the tension in the middle axle as advised for di2. Should I put it in max tension?
S-Works Tarmac SL5
Ritsuke
by Ritsuke
No one have an idea?
S-Works Tarmac SL5
ghostinthemachine
by ghostinthemachine
Is the chain too long?
If it is, the cage might not rotate round it's pivot far enough for the top jockey wheel to clear the 28t sprocket. Unless the jockey is centred on the pivot like the SRAM mechs are. Then it'll make no noticeable difference.
And, do all the other pivots in the mech move freely?
alcatraz
by alcatraz
If it works in the small chainring and not big chainring it's the chain length that causes the problem in the big ring.
Check how far back the cage pivots in the small/small gear combination. If it doesn't bottom out you could have some space for a longer chain.
Also don't just bottom out the B-screw. Ideally this should be in the ballpark when the chain is sized so you don't compound errors and get the wrong chain length. Depends on how you size the chain but to safely take modifications (like ospw, etc) into account you basically need to size in small/small combo and go as long as possible. You'll end up with less friction but if the chain is too slack and slaps chainstays or small cogs won't shift you might need to take a link out. Still easier than to "put a link back in" :lol:. (assuming you use quick links)
Ritsuke
by Ritsuke
Thanks, I'll check it out. But if I understand correctly you're saying my chain is too short at the moment?
S-Works Tarmac SL5
alcatraz
by alcatraz
Yes, I and another poster suspect that.
A picture with the combo in small/small and small/big would help. (front/rear)
