Stem top cap and spacers above stem
biwa
by biwa
Sorry for the trivial/stupid question, but just realized both the stem top cap and the 10mm spacer on top of my stem are free to rotate while the stem bolt stays fixed. Is this normal or is it a sympton of something not tightened enough?
RECAR77
by RECAR77
Does the headset have play?
If yes then the headset wasn't adjusted correctly.
If no the headset adjustment bolt got loose after the stem was tightend. Just tighten it again so it's barely tight. It wont affect headset adjustment until you loosen the stem bolts.
Sent from my moto g(6) using Tapatalk
biwa
by biwa
RECAR77 wrote:
Tue Jan 28, 2020 8:33 am
No play from the headset. Just to clarify, if I tighten the top cap bolt now it won't increase the load on headset bearings because the stem bolts are tightened? As a side question, how do I prevent this from happening in the first place? Was there something I potentially did wrong before tightening the stem bolts?
wheelsONfire
by wheelsONfire
Top cap bolt is tightened (not stem bolts) until there is no play at headset or fork and fork crown race.
Then tighten stem bolts. Then it doesn't matter if the headset top cap is taken off. It is there for visual appearance.
Aka, it's not any danger if it come loose. Just tighten it to 1-2Nm.
Bikes:
viewtopic.php?f=10&t=156137
Open *UP* (2016.04.14)
Ex bike; Vial EVO D
DaveS
by DaveS
Loosen the stem clamp bolts and tighten the to cap to properly preload the headset bearings. Then retighten the stem.
Something moved to cause this problem. The expanding plug may have moved or if this is a new setup, the bearings may have settled a little. If it occurs again, the plug is slipping.
ms6073
by ms6073
Agree tha the expander inside the steerer tube has moved under torque and needs to be loosened, pushed back down, and then re-tightened to specified torque.
biwa
by biwa
DaveS wrote:
Tue Jan 28, 2020 2:36 pm
Will try again, thanks. Just curious, what may cause the expanding plug to slip?
biwa
by biwa
wheelsONfire wrote:
Tue Jan 28, 2020 10:47 am
Sorry, meant to say tighten the top cap bolt (corrected now) after the stem bolts are tightened. I preloaded the bearings before tightening the stem bolts as you described, so is it correct to assume any further tightening (e.g. 1-2nm as you suggested above) of the top cap bolt afterwards will not change the load on bearings?
DaveS
by DaveS
There is no reason to further tighten a top cap after preloading the bearings.
wheelsONfire
by wheelsONfire
biwa wrote:
Wed Jan 29, 2020 12:54 am
No, do not preload the top cap bolt more afterwards. If anything, after the stem is preloaded and torqued (fixed at the steerer tube), you can loosen the top cap bolt.
Just enough torque, so the top cap screw doesn't unwind.
The bearings can't be more or less preloaded once the stem is "fixed" at the steerer tube.
Bikes:
Ex bike; Vial EVO D
synchronicity
by synchronicity
Did you cut your fork steerer tube short enough?
If it's too long sometimes the headset cap can hit that, it feels tight but not actually compressing where it should...
Reno
by Reno
Sometimes top cap may hit the expander if you don't have correct size spacer underneath it. Then it will not do the job properly. So make sure the spacer above the stem is fully contacted by the top cap.
thedanplasse
by thedanplasse
if it was hitting the expander the headset would have play.
2018 Specialized Tarmac Expert Sl5
Reno
by Reno
thedanplasse wrote:
Sun Feb 02, 2020 4:40 pm
Most likely yes.
