Tires with actual mounted width of 27-28mm after broken in on 19c or 21c rims
biwa
by biwa
Am looking for clincher or tubeless tires with the following characteristics (if one exists :lol: ):
  • 27-28mm actual mounted width on 19mm or 21mm internal width rims (after ridden a month or two, so it's the final width not the newly installed width)
  • Supple ride feel and good grip when dry
  • Decent puncture resistance
  • Good rolling resistance, as good as or better than Pirelli P Zero Velo 4S for example
  • Compatible with carbon rims
samarskyrider
by samarskyrider
Subscribe
TobinHatesYou
by TobinHatesYou
25mm Vittoria Corsa G2.0 (TLR in my case.) Measured 27.5mm on 19mm rims.
Reno
by Reno
biwa wrote:
Wed Jan 22, 2020 7:28 am
Michelin Power Competition ticks all the boxes...
rides4beer
by rides4beer
25mm GP5000 clinchers measured right at 28mm broken in on my 21c rims. Fantastic tires, haven't had a single puncture on two sets, great rolling resistance and grip. Easy mounting, didn't even need levers (when new I lay them in the sun for a while to soften them up).
jmfreeman535
by jmfreeman535
I'll second the 25c GP5000's. I have about 1500 miles on mine, and they are still measuring 28mm on 21mm rims (CLX50). Performance wise, I have no complaints, whatsoever.
TobinHatesYou
by TobinHatesYou
My 25mm GP5Ks measured 26.8mm on 19mm rims.
bm0p700f
by bm0p700f
25mm irc roaditle tubeless are 27.5mm on 19mm internal width rims.
IRC formula pro 28mm are 28m. On the same rims.
I ha e measured the 25m corsa controls 2 tlr tyres I have mounted. They look like they are 26mm.
IrrelevantD
by IrrelevantD
Schwalbe Pro One 25c (old ones, not the new 2019 ones) measured right at 28mm on my HED Jet+ (21mm internal).
Bigger Gear
by Bigger Gear
Vittoria Corsa Control 700x25 on HED Belgium+ (20.7mm innner), once stretched measures 28.3mm wide and ~25.8mm tall (more error bar on this measurement). I have not measured the newer Corsa Control 2.0 as I have a good stock of the original.
For good weather riding on a mix of pavement from smooth to rough chipseal, I really like these tires as a good compromise of ride/durability/speed.
EDIT: Sorry missed the part about carbon rim compatibility. I will say that on my ENVE 3.4 I've ran regular Corsa G for a lot of km and I'm still here in one piece.
Reno
by Reno
I think Conti GP5K might be too wide for you with the 21mm wide rim. I have those with 21.5mm wide and the external width is then. More than 30mm, 30.5 IIRC... I had never had flats with GP4K's and shortly after I started using GP5K's I had a few. So to me the puncture resistance is not as good as Power Competition, which is more supple and faster... I would like to try Corsa and maybe I will.
schlafen
by schlafen
Michelin Pro4 Endurance V2 clincher, 28mm inflated on 19mm internal rim
Sent from my SM-G960F using Tapatalk
IrrelevantD
by IrrelevantD
Reno wrote:
Sun Jan 26, 2020 1:36 pm
What size are you seeing that with? I ask because I have 28c 5kTLs on 25mm internal rims (Easton AX) and they measure out at 31mm. I'm considering some 21mm internal deep sections for road use and the question of tire width started to pop up for me as well. Had hoped the 28s were closer to true 28~29 on 21mm internals.
fa63
by fa63
I just mounted 28c GP5K tires on Reynolds 41 wheels, 21mm internal width. They are at 29mm at 85 psi right now, waiting to be ridden for the first time.
Reno
by Reno
IrrelevantD wrote:
Mon Jan 27, 2020 2:01 pm
Apologies for not remembering to add the width. It's the 28mm version. More details with a picture in Allez Sprint topic, page 94.
viewtopic.php?f=3&t=133529&start=1395
