EEwings All Road + Sigeyi 110mm 3-5 spider
elfuinha
by elfuinha
kode54 wrote:
Thu Feb 13, 2020 9:59 pm
I ordered from a UK company that had 10 in stock. So, shouldn't be delayed much...just the shipping to the US.
Hello
Do you know when it will arrive?
regards
elfuinha
by elfuinha
Ordered mine today too...
kode54
by kode54
@elfuinha, you got yours already?
Mine should arrive today or tomorrow.
- Factor 02 VAM Disc + DA9170 + Enve 4.5AR CK CL hubs
- Moots Vamoots Disc RSL Titanium + DA9170 + Enve 3.4AR CK CL hubs
- Factor LS Disc + DA9170 + Enve G23 CK CL hubs
- Allied Able + DA9170 + Enve G27 CK CL hubs --> outgoing
CLEAR
by CLEAR
Following this... im interested as well. Thanks for the update.
kode54
by kode54
I received the PM spider. The only change I did was to remove the Sigeyi sticker since it is halfway hidden under the crank arm. Otherwise, the fit and finish is excellent. Upon close inspection, it does appear flipped because the dip in the outer edges tend to favor the correct side (non-flipped) but most will not notice the difference unless really looking for it. I need to park the images somewhere so I can post them.
elfuinha
by elfuinha
Hello
My should arrives next thrusday. I will remove the sticker too...
Please send pictures... Glad it fit...
Best Regards
Nuno Pires
elfuinha
by elfuinha
Hello
The Sigeyi Spider fits... According with kode54 that already received the spider if fits great...from the pictures he send me...
I've ask permission to put his pictures here... But it looks really good and it doesn't look that the spider is reversed with out the sticker.
Mine is still in transit... Hope middle next week I will receive it.
Still waiting on the ride report from kode54, but I think it will be the cheaper solution to have Power with this crank.
elfuinha
by elfuinha
Here are the pics
AXO-Bicycle-power-meter-SRAM-ROTOR-crank-Chain-Wheel-Bilateral-power-meter-for-SRAM-RED-Force.jpg
kode54
by kode54
Thx for posting Nuno. I used some copper anti seize, which I didn't clean up. A few issues with installing the PM spider. Had issues wiht the Ti bolts...one of which snapped off but was able to extract out. I torqued to recommended torque, but because the spider interface and the eeWing bolt area wasn't flush, the bolt head was at an angle and 8Nm seems to be too excessive wtih pressure on 50% of the bolt head so I guess that made it snap off. I never had any issues torquing to 8Nm with the Cane Creek spider since it was more flush and even with the bolt head area.
Other than that, fitment was excellent once I got it on...I ended up torque to 4.5Nm and seems fine for a bolt size this small.As mentioned, by removing the attached sticker, its difficult to tell if the spider is reversed or not...but from I'm told, the power reading is flipped. Left is Right.
I haven't taken to the road as I am cleaning off salt encrusted bottom bracket (done while crank was out), repacked grease on headset and hubs.
elfuinha
by elfuinha
Hello William
About the torque of the bolts... Cane creek issue a flyer that came with my crank and now it's 6Nm max.
I already snapped a ti bolt to... Going 8Nm.
Got my spider today so putting it tomorrow.
Mostlyharmless
by Mostlyharmless
lol I broke a spider bolt as well. Spare bolt just arrived today. There’s no way that 3-bolt spider requires torque of 9nm, they must’ve mis-labeled it. Now I’m tightening them to 5nm and they work perfectly
elfuinha wrote:Hello William
kode54
by kode54
Haha. I thought I was the only one. But no way a M4 Torx bolt should be higher than 5.5Nm...let alone 6Nm. I thought 8Nm was a bit much but it worked the first time with the Cane Creek spider...just not with the Sigeyi spider. I re-evaluated the size of the bolt and did 4.5Nm and it was plenty.
elfuinha
by elfuinha
Today I mount the Sigeyi on the EEWINGS... put 6Nm and no problems at all.
Will try it in the weekend.
elfuinha
by elfuinha
Pics on the Bike...
kode54
by kode54
Looks great!
