EEwings All Road + Sigeyi 110mm 3-5 spider
elfuinha
by elfuinha
Hello
Does anyone use the EEWINGS with a powermeter Spider from Sigeyi.?
Since the 3 bolt pattern is reverse I think is possible to use this spider.
Any thoughts on the matter.
Let me know please.
elfuinha
by elfuinha
Anyone on this subject...??? :noidea:
alanyu
by alanyu
It looks possible to use AXO on eewings, but one chainring bolt is then under the crank. Is there enough clearance? Another question is would the chainline be OK then?
And why do you want that combo? On the function side, Favero pedals are better; on the WW side, skypivot + AXO is lighter and cheaper.
elfuinha
by elfuinha
Thanks for your answer.
Already have the EEWINGS, and really like it.
Don't want to increase the Qfactor. Using pedals.
mattsurf
by mattsurf
There is no increase in Q Factor with Favero Assioma
elfuinha
by elfuinha
replacing the Pedals that i use, the is an increase of 2mm per side
by Nefarious86
Is there not 2mm of room on your cleat adjustment?
Sent from my SM-N976B using Tapatalk
Using Tapatalk
icantaffordcycling
by icantaffordcycling
elfuinha wrote:
Thu Jan 23, 2020 11:01 am
Just use 2mm of pedal washers?
elfuinha
by elfuinha
I don't want to increase the Qfactor.
EEwings are 160mm quite large.
My Pedals Keywin have -3mm spindles = 52mm
By using the favero i will see an increase of 2mm per side.
hope i explain it better.
alanyu
by alanyu
I feel you.
160mm Qf is large compare to normal value 145~150mm. I also prefer smaller Qf.
Ruben58
by Ruben58
I once inquired with Power2Max wether their PM would work and I was told it wouldn't because the bolt pattern is upside down and there would be clearance issues. Theirs however has a small bump on the spider which normally would be opposite the crank arm, but not with the EE wings because of the rotated interface.
elfuinha
by elfuinha
alanyu wrote:
Thu Jan 23, 2020 11:58 am
I feel you.
Right now it's 154mm with the smaller Spindles, it's ok, could go to 148mm, with Keywin smaller spindles, but i think the Bont's will rub the crank arms.
elfuinha
by elfuinha
Ruben58 wrote:
Thu Jan 23, 2020 12:01 pm
Yes i also look in to this...
But i think Sigeyi will work because there is a redution in height at the end of this PM, and the charging port will be used in the same way...
also here in Portugal is impossivel to check this... also this PM is only available by ALIEXPRESS.
elfuinha
by elfuinha
hello
Anyone as tried this????, with the EEWings Allroad
https://www.sigeyishop.com/products/sig ... 7231668277
Jhomewood
by Jhomewood
Maybe look for an old three bolt quarq spider
