Fuji Transonic 2020
VTR1000SP2
by VTR1000SP2
Hexsense wrote:Fuji bikes Taiwan 's facebook account posted many pictures.
But one thing caught my eyes is non-standard steerer tube.
Yes likely how they keep the HT slender yet have room for cable routing?
RedbullFiXX
by RedbullFiXX
Hexsense wrote:
Fri Jan 17, 2020 10:24 pm
Harder to manufacter than a sraight tube (see BMC issues)
Cyclocross, in general, is about riding the wrong bike for the conditions.
mmeysarosh
by mmeysarosh
RedbullFiXX wrote:
Fri Jan 17, 2020 11:08 pm
It is harder to manufacter any carbon tube with a sharp bend over even a moderate curve as carbon, more so at certain grades, can be rather brittle when putting the layup in a mould. It appears to be their solution to permit the hoses to come through.
Given the use of modern engineering and CAD tools and experienced far east factories, the frame will offer fairly reasonable performance in terms of frame parameters, aero is entirely an other matter. The S or about 52cm size becomes the odd duck with a 55mm trail. Lively and sharp on most roads, but a possible handful on fast descents. The Red AXS 1.1 build is specified to weigh in at 17.09lbs/7.75kg, but those Oval Concepts 950 weigh in at 1770g for a 50mm depth. You can certainly lose about 170-200g at that point pretty easily and get what would be likely a better wheelset. Add Dura Ace and your below 7.5kg.
Looking at the certain visual cues, I see a more all around aero approach then an all out aero bike. The seat tube and post doesn't go to the depth of some and the rear seat stays show some degree of deflection in design. As for the rim brake compatibility, my guess is that this was on the screen for a bit as its parent likely caused delays with its recent bankruptcy restructure. Since they had the design and possibly the mold done, it come to bore. I see rim brake designs still viable in the more climb oriented designs where STW becomes the priority as does overall weight, but not here.
VTR1000SP2
by VTR1000SP2
Anyone else think it looks a lot like the BMC Roadmachine?
VTR1000SP2
by VTR1000SP2
mmeysarosh wrote:As for the rim brake compatibility, my guess is that this was on the screen for a bit as its parent likely caused delays with its recent bankruptcy restructure. Since they had the design and possibly the mold done, it come to bore. I see rim brake designs still viable in the more climb oriented designs where STW becomes the priority as does overall weight, but not here.
Think you’re right. Looking at the UCI frame list, it’s showing this new Transonic was tested in the first half of 2018.
VoukDi89
by VoukDi89
Guys just received mine :lol: . Size small 52 still with the papers and the weight is 7745. So with campagnolo Bora One 50 clincher silca tubes continental grand prix 5000 tires, carbon handlebar and saddle I expect to go 7.3 approx.
Hexsense
by Hexsense
VoukDi89 wrote:
Mon Jan 20, 2020 1:40 pm
Looking nice.
Can you confirm if the steerer tube is round on your model?
It seems that the 2nd tier class use round steerer tube and 1.1 class use non round steerer tube. But I can not confirm it.
VoukDi89
by VoukDi89
Hexsense wrote:
Mon Jan 20, 2020 8:51 pm
Looking nice.
Just give me few days my mechanic received and now he send to me so I will have it at the end of the month. From videos he send me I think is round but I will confirm in few days.
RedbullFiXX
by RedbullFiXX
pedals ?
PsyDoc
by PsyDoc
I got an email reply from Fuji stating that the disc versions of the frame (1.1 and 2.1) will come with the "ovular, non-round, style fork". "This ovular shape allows us to route the brake lines and Di2 wires under the bar tape, through the stem, and into the frame without ever being exposed which both creates clean lines and improves the aerodynamic profile of the bike. The Transonic Disc 1.1 frameset will include the frame, fork, headsets, stem, seat post, derailleur hanger, front and rear thru-axles, and bars."
prebsy
by prebsy
1.1 with all that for 2k is nice. if fuji would let you get the right stem and handlebar width if purchased through a brick and mortar that would be a truly killer package, I've always found them to be flexible with customer service.
VTR1000SP2
by VTR1000SP2
prebsy wrote:1.1 with all that for 2k is nice. if fuji would let you get the right stem and handlebar width if purchased through a brick and mortar that would be a truly killer package, I've always found them to be flexible with customer service.
I asked this exact question and they said at this time of get what is average for the frame size starting with 38mm for the smallest frames and going up from there.
VoukDi89
by VoukDi89
Hi guys just arrived. So first look is awesome look stiff. I weight the bike include garmin mount 7580. So after my upgrades I will send you again final weight. Stem is overweight so I will change stem and handlebar.
Guys I just did the final upgrades bike is suppers tiff amazing ride. Final weight 7.430. I use 120mm stem S-Works venge in order to be nice on the original spacer. Bike can reduce a lot of weight if you go for carbon saddle and integrated handlebar. 7. 430 weight included everything pedals favero assioma duo wahhoo stem mount, bottle cages.
prebsy
by prebsy
sweet ride. do you have the weight of the oval concepts stem?
VoukDi89
by VoukDi89
prebsy wrote:
Wed Feb 05, 2020 5:32 pm
Yes the 90mm stem weight is 240 grams.
