Campagnolo 11 / 12 speed compatibility
joeyb1000
by joeyb1000
The only issue between 11 and 12s cranksets is that pre-HO 11s are 7.6mm apart and 11HO/12s are 8.0mm. This affects the shifting on 12s mechanical FDs. EPS doesn't care.
I did not test to see if the difference was in the chainrings or the crank arms.
ChristianB
by ChristianB
I got a reply from power2max today. They stated that their 4-arm cranksets are compatible with both 11 & 12 speed, which, according to them, is confirmed by Campagnolo. One should use 12-speed chain rings for 12 speed though.
MrCurrieinahurry
by MrCurrieinahurry
Can you post a link to which crankset this is please?
ChristianB
by ChristianB
Unfortunately not, as it is the previous 4-arm version (build when there was 11-speed). It no longer shows on their webpage. But as I understood them, all their 4-arm campagnolo cranksets work with both 11 and 12 speed mechanical. I know the cranksets are manufactured specificly for power2max, so who knows about spacing...
2000m2
by 2000m2
Similar question - my used bike came with 11 speed Super Record, 4 arm crankset (175, 50/34). I needed to change the crankset due to arm length hurting my knees and gearing, so I ended up with a 5 arm Super Record crankset in the correct size for me (172.5, 52/36). Finding the correct 4 arm 11 speed crankset has proven elusive. My question is if I can use a 12 speed crankset with everything else being 11 speed? While the current crankset functions great, I really prefer the newer 4 arm appearance.
joeyb1000
by joeyb1000
2000m2 wrote:
Sun Nov 07, 2021 5:18 pm
Yes
robertbb
by robertbb
joeyb1000 wrote:
Mon Nov 08, 2021 3:04 am
Yes
The chainline is different as is the chanring spacing. Not so sure it's going to work very well despite people saying so on the interwebs.
Remi67
by Remi67
Hi everyone,
Does anyone know if it is pssible, or ever tried to install a 12sp rear mechanical derailleur cage on a 11sp rear mechanical derailleur ?
Thanks !
Rémi.
RichTheRoadie
Tinker, Taylor, Tart
by RichTheRoadie
BigPoser wrote:
Fri Sep 04, 2020 5:34 pm
Will the 12s chain play nicely with my 11s Praxis chainrings?
Yes, you'll be fine.
ChristianB wrote:
Sun Sep 26, 2021 7:01 am
I have an existing 11-speed Power2Max chainset (4-arm) that I would like to use with an upcomong 12 speed build. Is this possible? Can I use the 11-speed chainrings or should I install 12-speed?
As above, 11v rings will be fine.
Yup, good to go.
robertbb
by robertbb
RichTheRoadie wrote:
Fri Nov 26, 2021 7:54 am
Yup, good to go.
I'm not totally convinced this is true.
The chainline and distance between chainrings on 12 speed (and for that matter Potenza HO 11 and Centaur 11) is 44.5 and 8mm respectively.
The 2015+ Chorus/Record/Super Record shifters and front mech are designed around 43.5 mm chainline with 7.6 mm spacing.
There's not a lot in it, sure, but whether or not it works may come down to frame size/spec. You'd definitely want to use a barrel adjusted with the front mech to dial it in.
SL06
by SL06
MayhemSWE wrote:
Fri Sep 04, 2020 9:35 pm
No idea about real world experience, but according to Praxis themselves their current chainrings does not work satisfactorily with Campy 12. They did hope to have new fully compatible chainrings available sometime this coming winter though.
From Praxis wb site 29nov 2021: CAMPY – Praxis rings shift great with the EPS and mechanical Campy 10/11/12sp drivetrains...
https://praxiscycles.com/product/road-rings/
RichTheRoadie
by RichTheRoadie
robertbb wrote:
Sat Nov 27, 2021 2:50 am
I've done it on a number of frames - it works perfectly well.
bikeboy1tr
by bikeboy1tr
I hope the Praxis rings are stiffer than the Campy 12 rings cause mine came in at 0.157kg with fasteners. They claim 0.158 52/36 not sure if fasteners included.
viewtopic.php?f=10&t=154188
2018 Colnago V2R Rim Brake
2019 Colnago V2R Disc Brake
patrikantonius
by patrikantonius
Hi, has anyone tried mounting 12s chainrings on 11s cranks?
smokva
by smokva
Has anyone tried Campagnolo 12 speed with Dura-Ace 9100 cranks?
