Hair dryer would be handy.choochoo46 wrote: ↑Wed Jun 23, 2021 4:20 amI've been using MSW for about a year and love it for the fastest chain as well as never getting my hands dirty when working on the drive train. I rotate through 3 chains. Do all three at once, about once a month. I tend to let each chain go about 500 miles each, but our roads are pretty clean and I rarely ride in the rain.
Recently I got an ultrasonic cleaner to chean the chains after their first wax & use using the MSW instructions here https://moltenspeedwax.com/pages/ultras ... your-chain.
Has anyone tried drying their chains in the oven after the ultrasonic cleaning. I found using an air compressor somewhat tedious and I think it somewhat variable depending on your technique. I noticed that an oven was used in this GCN / MucOff video. https://youtu.be/xSCXyE5cnFo
I'm thinking 20 min at 250 deg F would do the trick (since water evaporates at 212 deg F).
Finding molten speed wax or food grade paraffin wax in denmark/europe
My hack for both drying the chain off initially and also curing the wax faster (obviously not straight out the pot).
IG: RhinosWorkshop
IG: RhinosWorkshop
yeah, I've used both a hair dryer and hot air gun, but I'm lazy. And I rationalize it that I won't consistently heat the entire chain. I have an old toaster oven I don't use anymore that seems perfect suited to the job!
2018 Fuji Transonic 2.5 rim (6.90kg)
2020 ICAN AC-388 cyclocross bike (8.41kg)
2021 Trek Emonda SLR RSL H1 rim (5.65kg)
1980s vintage ALAN Super Record (haven't weighed it)
I faced a similar situation when looking for paraffin wax for a personal project. Initially, I struggled to find it locally, but then I turned to online stores specialising in beauty and wellness products. These stores had paraffin wax in stock, which might be a viable option for your needs.
My experience centred around learning how to use paraffin wax to treat dry and damaged hair. It wasn't straightforward at first. After some research, I learned the proper method: melting the wax and mixing it with a nourishing oil like jojoba or coconut. Applying this mixture to the damaged areas of my hair and leaving it for about 10 minutes before washing it out made a difference.
Alan
My Bikes
My Bikes
