Brakes: Duraace R9100 clearance for 30mm OD rims
Hi guys, a question for those that might own the 9100 brakes.
Shimano states that maximum rim width should be: 20.8 - 28 mm with a maximum tire size 28C
https://bike.shimano.com/en-EU/product/ ... R9100.html
I have no expirience with these brakes but I'm wondering if anyone has managed to fit a 30mm OD Rim on these brakes any if there's room for adjustment.
For comparsion, Cane Creek state EE brakes can do 19mm to 28mm.
Rim brake clearance is largely determined by the fork and frame, not the brakes themselves. I have 9100 rim brakes and can clear 32mm tires with 4mm room on each side. But my fork has a very long CTA which means the brake’s mounting studs are further away from the front wheel’s axle. The same brake on a different fork from mine such as an Enve fork will have much less clearance due to the fork’s short CTA. You need to specify your fork and frame and see if others with the same fork/frame and brakes can offer actual clearance measurements. Generally Trek bikes with rim brakes will have the most tire clearance while Colnago bikes have the least. Other bikes will fall somewhere in between.
That's super interesting. I am looking at a Rim Brake TCR Advanced SL (2020) which is principially the same as the latest generations running a a LB Rim. This Rim measures 23mm internally and 30mm externally which is my main concern. I'll be running 25mm GP5000 which I anticipate will balloon to 28mm on this Rim. My concern is is the actual rim width will cause issues with it's relationship to the fork.
- wheelsONfire
I don't get why they design a rim this wide for rim brake framesets. It's really pushing things so far it would atleast make me stay off.Shpox wrote: ↑Sun Dec 29, 2019 4:05 pmThat's super interesting. I am looking at a Rim Brake TCR Advanced SL (2020) which is principially the same as the latest generations running a a LB Rim. This Rim measures 23mm internally and 30mm externally which is my main concern. I'll be running 25mm GP5000 which I anticipate will balloon to 28mm on this Rim. My concern is is the actual rim width will cause issues with it's relationship to the fork.
Well, each to his own i guess
Bikes:
Open *UP* (2016.04.14)
Not sure if this helps but I have a MY2016 TCR with Dura ace 9000 brakes and Light bicycle AR46 rims.
Shimano says the maximuum rim width (with carbon pads) is 19-28 mm. The AR46 rims are 28mm wide externally.
The biggest issue is the distance between the brake pad and rim braking surface. I was unable to fit brand new pads in the alloted space. Instead I used older pads with about 60% life left on them and it works.
The AR56 rims could fit but you will have to grind down the pads quite a bit.
