Farsports F1 Integrated Handlebar/Stem
it seems great for an olympic gold medal
cool! Now I want to try this F1 on my new Basso also...lazyriderzhao wrote: ↑Sun Jul 25, 2021 2:32 pmit seems great for an olympic gold medal
FOIL 20 w/DA 9270 + ENVE 60/67 2023 wheels - GP 5000TR S 28MM
Ridley GRIFN, 105 Di2 12s + Nextie AGX45 (40mm wide) aerogravel wheels - Terra Speed 45mm
Considering that Anna is not on a cycling team, she must have bought the bike and the Farsport bars herself. Quite an endorsement! Wonder if Scott will spring for a gold bike for her.lazyriderzhao wrote: ↑Sun Jul 25, 2021 2:32 pmit seems great for an olympic gold medal
Cannondale Supersixevo 4 (7.05 kg)
Retired: Chapter2, Tarmac SWorks SL6, Orbea, Dogma F8\F10, LOW, Wilier, Ridley Noah, Cervelo R3\R5\S2\Aspero, Time Fluidity, Lapierre Pulsium, Cyfac, Felt, Klein, Cannondale pre-CAAD aluminum
I noticed they appear to made from plastic/nylon/abs? Can't I just pick up a generic alloy one?
Being made out of polymer is not a problem it’s more on the dimensions of some of their sleeves (seems 3d printed)theStig wrote:I noticed they appear to made from plastic/nylon/abs? Can't I just pick up a generic alloy one?
You can’t use a generic aluminium one since it needs to match the length of the clamping area.
That’s very subjective and (to me) a lot more related to the geometry. A combo imposes certains angles (I would prefer having the drops with a bit less angles; I could using the +2deg sleeve instead of the -2 position…. But then my stack it too high)“random101” wrote:How is the comfert on these? The sqaure edge looks like it would suck if you hold your hands in the middle of the bars?
SuperSix Evo my2020 and my2021.
Can someone advise what do i need to make top section of cockpit flat, without any spacer on top of it?
The cannondale stock stem cap is not as wide as cockpit, so i think some of you guys used some wider stem cap?
Thank you.
Thank you.
SW SL8 RTP 56cm @ 9270 / CLX II / CS OSPW / CEMA BB
S Epic 8 L @ XX T-Type / Berg Ratheberg 30 / Quarq / Fox Transfer SL 100mm / 3p
Hi, I'm using an OD2 ti cap from S-parts and 3rd-party plug from carbon-ti
I cut the steerer tube just on cockpit level, and using 2mm spacer on top of it which is barely visilble, and i am happy with that, no need to change plug.lazyriderzhao wrote: ↑Sat Jul 31, 2021 2:17 pmHi, I'm using an OD2 ti cap from S-parts and 3rd-party plug from carbon-ti
