Farsports F1 Integrated Handlebar/Stem
As someone else said.. choices are very limited if looking for an integrated 38mm 110mm with a short reach.. I'd pretty much given up and was settled on the Pro-Vibe bars and separate stem but had stalled as the only reason to replace my existing Zipp Aero SL70's was to get DI2 mounted in the bar ends..
Now it seems I have a new answer!
Any chance of some more pics of these please? front on and side on?
- Dan Gerous
On a Focus Izalco Max:
On a Cannondale SuperSix Evo:
I received mine this week, quite pleased with it. I have/had Syncros/Scott and FSA/Vision integrated bars and the finish and manufacturing quality of the Farsports is as good, if not better IMO. Plus, it's much lighter, available in more sizes, cheaper... Personally, I find the fit (angle/tilt of the bars, reach, flare) much better as well and they look a lot cleaner, slicker more modern, but that's all very subjective.
I got a 380x100 size, I don't have a precise scale to check, but I suspect they're under 300gr given the weight posted by refthimos for a 420x120 and I got the SuperSix Evo specific 3D printed spacer as well (5mm stack, same as the old Evo's thin alloy bearing cover, the Evo pictured above has that spacer plus 1 7mm Cannondale spacer, so it can be more slammed than that one). The top cap I received is a more generic round one, not the shaped one in the Farsports pictures, I wasn't planning to use it anyway, I will stick with the much lighter Cannondale compression plug and top cap.
As already mentionned, the Garmin mount is a well designed, solid, stiff alloy structure, the GoPro mount underneath is also made of alloy and to answer someone's question, is removable (probably weighs at least 10gr) and the Garmin insert uses the same mounting bolt pattern as the easy to source K-Edge inserts, so you could also use it with Wahoo, Lezyne, Sigma, Omata and most computers.
I won't have the frameset to install these for a little while so I can't confirm how hard it is to route wires/hoses through them, the two holes above the headset are not big so it will be tight, the Di2 wire heads probably can't fit through if a brake hose has already been fed, so I would start with the wiring before the brake lines. I will also have to be careful with the hose lengths, being fully internal, I'll probably add a bit of slack in the downtube to have enough wiggle room to easily take the bars off for traveling and to clean the headset bearings from time to time without having to disconnect the hydraulic hoses...
- Dan Gerous
Are the gold stripes somehow removable?
@Dan Generous
Some people have modified the cable routing on their Super Six to be fully internal, even with mechanical shifiting. I haven't seen it done using this bar and stem (yet). Could you check if the size of the holes above the headset allows brake hoses and 4 or 5 mm shift cable outers to be routed internally?
Yeah it does look better with a round top cap, but still odd. I was seriously considering this handlebar but it honestly can't be considered a premium product with such a glaring flaw. To my eyes, the break in a smooth line is jarring. After all it's supposed to be aerodynamic. That said, kudos to Farsports for the wide variety of sizes and bike compatibility. This is what the market will increasingly need, so I hope the product stays in their lineup and brings an improved 2.0 in the future.
same. looks like an afterthought. Maybe the AbsoluteBlack one piece top cap will fit and may streamline the look a bit.
Mep wrote: ↑Mon Jan 06, 2020 3:54 pmYeah it does look better with a round top cap, but still odd. I was seriously considering this handlebar but it honestly can't be considered a premium product with such a glaring flaw. To my eyes, the break in a smooth line is jarring. After all it's supposed to be aerodynamic. That said, kudos to Farsports for the wide variety of sizes and bike compatibility. This is what the market will increasingly need, so I hope the product stays in their lineup and brings an improved 2.0 in the future.
-- Factor Ostro VAM gen2 Disc
-- Specialized Aethos Disc
-- Guru Praemio R Disc
-- Factor LS Disc
-- Factor LS Disc
- Dan Gerous
Thing is, the stem is actually 1 1/4 so many top caps for 1 1/8 are just soooo close to the edge, too much between pushing down the stem itself or pushing down the shim only... Are their any light 1 1/4 top caps around? For Giants/Scotts/Canyons?kode54 wrote: ↑Mon Jan 06, 2020 4:16 pmsame. looks like an afterthought. Maybe the AbsoluteBlack one piece top cap will fit and may streamline the look a bit.
- Dan Gerous
I'll check when I get home... I doubt it will work though... and if it does, mechanical cables don't like sharp bends which would be unavoidable if going fully internal from those holes, I think shifting would suffer.N1720 wrote: ↑Mon Jan 06, 2020 10:13 am@Dan Generous
Maybe a slightly odd request (!) but would someone be able to do an outline with a couple of measurements of the bottom of the stem.
I am trying to work out how different it is compared to the integration parts on the addict RC.
Cheers
Cheers
