Farsports F1 Integrated Handlebar/Stem
ry5n
by ry5n
My steerer shim is also heavy at 15.5 g and was wondering about a lighter option too. Couldn't find anything online.
Was thinking of asking Lucendi if a carbon reinforced 3D-printed shim makes any sense.
Or, maybe custom carbon? I know some fabricators will do custom tubes and a shim isn't much more complex than that, in theory. Big caveat is I'm not an engineer :P
moonoi
by moonoi
I just picked up the F1S for 11500 baht + 1500 baht for the SuperSixEvo spacer, this compared to 15000 baht for the super heavy cannondale know system/bar stem, quite a bargain and looks way better too
C36
by C36
Shim used to be 5g but were breaking very easily.
F1 Bar stand-alone was (in your same size) 308g
and 345 with shim, heavy top cap and screw and gps support.
ry5n
by ry5n
The early production runs of the classic F1 were lighter for the same size compared to later. Looks like some didn’t support internal routing, maybe that’s why?
My recently-purchased F1 in 360 × 100 is 331 g without computer mount and shim. Definitely not lighter than the new one :)
Classic F1, 360 × 100, 331.2 g
ry5n
by ry5n
Aryeh, where did you order your alloy computer mount bolts? I’m not sure if the classic bar uses the same ones either. Anyone know?
Aryeh
by Aryeh
ry5n wrote:Aryeh, where did you order your alloy computer mount bolts? I’m not sure if the classic bar uses the same ones either. Anyone know?
https://a.aliexpress.com/_mMuP8bO
ry5n
by ry5n
Aryeh wrote:
Fri Nov 18, 2022 5:33 am
Thank you!
Aryeh
by Aryeh
The mount bolts arrived today.
It's a big difference.Image
Ludo
by Ludo
Aryeh wrote:
Sun Nov 20, 2022 12:18 am
What size do they have?
Aryeh
by Aryeh
These are m4x16mm
theOrtherion
by theOrtherion
Hi guys. I just bought a farsports f1S handlebar. Is it just me or I can't fit the garmin mount correctly?
Any instructions?
Thank you.
Aryeh
by Aryeh
theOrtherion wrote:Hi guys. I just bought a farsports f1S handlebar. Is it just me or I can't fit the garmin mount correctly?
Any instructions?
Thank you.
You need to rotate the insert so the screws are positioned vertically. It seems wrong because the bumps on the insert don't align with the wider horizontally positioned holes on the mount but it works.
I think they messed up, the Garmin mount is the same as the Wahoo mount.
theOrtherion
by theOrtherion
Aryeh wrote:
Mon Nov 21, 2022 4:51 pm
Any instructions?
Thank you.
So i was doing the right way but for some reason it seem really off. My garmin mount is so tight that it scratched the back of my Edge 530.
Thank you for your help.
theOrtherion
by theOrtherion
Please delete. Double post
Aryeh
by Aryeh
The handlebar is installed. Installing it cost me almost as much as the handlebar itself because of the cable routing and brake bleeds.
My bike gained about 60g in weight but hopefully the aero gains will outweigh the weight penalty.
I'll post pictures when I get out on the road tomorrow morning.
