Farsports F1 Integrated Handlebar/Stem
Takeswood
by Takeswood
Hey guys, have you seen the price increase of farsport F1 ?
Firstly is no longuer available since months, secondly price increase. Hum...
Is only available on AliE, for 400€.
ultreia
by ultreia
Yes, 25% increase in price. Now it is almost at the same price level of a Vision Metron 5D/6D with a good offer.
req110
by req110
Wow, my two pieces are becoming and investment seems like.
SW SL8 RTP 56cm @ 9270 / CLX II / CS OSPW / CEMA BB
S Epic 8 L @ XX T-Type / Berg Ratheberg 30 / Quarq / Fox Transfer SL 100mm / 3p
ultreia
by ultreia
Hello
Anyone using this bar with Token Cable box?
bmcdrinker
by bmcdrinker
Finally my handlebar was delivered to Poland after a month of waiting. Luckily I purchased it before price had increased (340$).
Handlebar weights more than I expected. In size of 400x100 with computer mount it is 390g.
It fits very well with my Focus Izalco Max frameset.
It feels like it's not as stiff as my old alu-non aero-handlebar, especially in the sprinting position.
In my opinion, mount for Wahoo (ELMNT xxx) could be 1-2cm shorter
Juanmoretime
Administrator
by Juanmoretime
[quote=bmcdrinker post_id=1710272 time=1634716709 user_id=109575]
[/quote]
40 CM 3T Aeronova bars with my 100mm MCCK stem weight 263 grams all together. Light and not quite as aero although I'm satisfied with the set up.
ryanw
by ryanw
390g is heavy!
That's the same as my standard -12 120mm SL7 Tarmac stem with Enve SES Aero v2 42cm bars.
IG: RhinosWorkshop
Takeswood
by Takeswood
Juanmoretime wrote:
Wed Oct 20, 2021 10:33 am
bmcdrinker wrote:
Wed Oct 20, 2021 8:58 am
So your stem is approx 60gr ? Do you have a link ?
Original stem of izalco max and newmenn handlebar, weight is 450gr.
Juanmoretime
Administrator
by Juanmoretime
[quote=Takeswood post_id=1710329 time=1634729040 user_id=97497]
[quote=Juanmoretime post_id=1710295 time=1634722395 user_id=912]
[/quote]
[/quote]
[/quote]
No it's not. The Aeronova LTD weighs 192 grams. My stem 71 grams.
ericlambi
by ericlambi
Does the Focus use a D shaped steerer and route the cables through the head tube? I.e. could this bar work with similar designs that do this like the Factor Ostro with that spacer?
fizzaz
by fizzaz
Without a spacer provided by either Farpsorts or the OEM, do not do this.
Mcdeez
by Mcdeez
bmcdrinker wrote:Finally my handlebar was delivered to Poland after a month of waiting. Luckily I purchased it before price had increased (340$).
Yep,that mount is way too long. So weird
Sent from my Pixel 6 Pro using Tapatalk
ericlambi
by ericlambi
fizzaz wrote:
Mon Dec 06, 2021 3:31 pm
Right, it obviously will not work without a specialized spacer that allows the cables to route into the head tube. But that's exactly what it looks like is happening in the photo above. Hence, my question.
Vivo66
by Vivo66
How heavy is the mount? I've never taken mine off to weigh it but it is quite long and a possibly a bit overbuilt.
Would this fit?
https://r2-bike.com/DARIMO-Computer-Mount-long-Garmin
Maddie
by Maddie
My F1 Garmin mount is 17g with bolts. Darimo et al. won't fit
