Farsports F1 Integrated Handlebar/Stem
Pabloldv wrote:Can you measure the stem lenght and hoods c-c width please? Someone posted some time ago that the 120mm version was more like 130mm...
Sorry, only had a tape measure in inches. Looks to be around 15.75”. Very close to 40cm c to c.
The caliper is set to 120mm. You be the judge on how close it is dimensionally.
Thanks. Yes, quite accurate. Thinking of buying it for a Trek Emonda SLR 2019neema wrote:Sorry, only had a tape measure in inches. Looks to be around 15.75”. Very close to 40cm c to c.Pabloldv wrote:Can you measure the stem lenght and hoods c-c width please? Someone posted some time ago that the 120mm version was more like 130mm...neema wrote:Got mine a few days ago. They look pretty good except some voids in the steerer clamp part. Farsports said they're part of the foam molding and normal. Okay then.
My 40cm/120mm dimensions came out to be 368g with the computer mount up front.
This is mocking up the 3º adapter shim. You'll see a little sticking out below the stem
FYI, you either need to trim the 1 1/8" adapter or get a different headset cap if you don't want steerer tube extending above the stem. it sits a little proud atop the stem out of the box, unless I don't understand how to set this up correctly.
- VTR1000SP2
Any voids in your steerer clamp area?VeloCris wrote:
Mine just arrived size 40 110 stem
Focus Izalco Max - 4.84kg without pedals
Cervélo Áspero - 8.28kg
Trek Madone SLR Rim - 7.73kg
Standert Triebwerk Disc - 8.47kg
Nope! I think it looks good. I would def raise concern if it did https://i.imgur.com/yQ4YUSI.jpgVTR1000SP2 wrote: ↑Thu Aug 13, 2020 7:13 pmAny voids in your steerer clamp area?VeloCris wrote:
- VTR1000SP2
Thank youVeloCris wrote:Nope! I think it looks good. I would def raise concern if it did https://i.imgur.com/yQ4YUSI.jpgVTR1000SP2 wrote: ↑Thu Aug 13, 2020 7:13 pmAny voids in your steerer clamp area?VeloCris wrote:
Looks better than mine, but still looks like their tooling beats up the steerer tube clamp area. Those scoring marks in particular don't look great. I don't have another carbon stem to compare to, though. My aluminum ones look fineVeloCris wrote: ↑Fri Aug 14, 2020 3:50 amNope! I think it looks good. I would def raise concern if it did https://i.imgur.com/yQ4YUSI.jpgVTR1000SP2 wrote: ↑Thu Aug 13, 2020 7:13 pmAny voids in your steerer clamp area?VeloCris wrote:
+1, Their little convenient of using Tapatalk hurt other people's quality of experience with extra scrolling.
Sent from my Nokia 3310 using GPRS
Do you know if it is possible to place a Deda Alanera DCR directly on top of the SystemSix cable collector headset cover? (i.e., with no other spacers in-between)refthimos wrote: ↑Wed Dec 25, 2019 1:58 amSorry guys, didn't bother to weigh the Farsports spacer or the steer tube reducer. - and they're already packed up with my EVO framset and off to the painter. They are both plastic and can't weigh more than a handful of grams. The reducer in particular - I can't see that thing being more than 2g or so - there's not much to it.
I want to see how the EVO looks with the F1 - I'm now reconsidering the Deda Alanera DCR with the SystemSix, because I will need to bodge or shave the Cannondale spacers to "integrate" with the Deda. I may get another F1 to keep things looking tidy, especially if I like the fit and feel. TBD.
Or alternatively, if it is possible to leave out the SystemSix cable collector cover altogether, use a 3rd party low-stack headset cover (maybe even slamthatstem.com), then the Alanera DCR with the cables going straight into the Systemsix headtube tunnel?
Thanks!
- wheelsONfire
Do all of you have bite marks in the bars from torquing your shifters?
Bikes:
Open *UP* (2016.04.14)
- wheelsONfire
To me it seems (looking at pictures) this is just as bad as 3T.
Even so i never had a bite mark from mounting shifters, just stem.
Bikes:
