SRAM 1170 cassette with Shimano R8000
rich00
Post by rich00 »
Hi all,
Any compatability issues using a SRAM 1170 cassette with Shimano R8000? I've got a spare 11-26 cassette that I want to use since it has a 16. I've currently have a 11-28 and running 52/36 and finding that I'm missing the 16.
Cheers
Richard
Sent from my SM-G965F using Tapatalk
TobinHatesYou
Re: SRAM 1170 cassette with Shimano R8000
Post by TobinHatesYou »
No compatibility issues. SRAM cassettes are typically a little more chattery than Shimano due to slightly different teeth profiles, but they function.
GregR
Post by GregR »
The pitch of the Sram and shimano cassettes are slightly different. 3.69 mm vs 3.72 mm. It will work, but you'll get a bit more noise in some gears than others. I tried an Ultegra cassette with my old etap setup and swapped it out after a month or so because it drove me crazy. If you're laid back you'll be fine, if your finicky about everything you'll hate it.
http://blog.artscyclery.com/science-beh ... y/#content
