Disc brake bike - QR or Thru Axle?
Brought a Kinesis 4s frameset (dual disc/rim model) with a plan to build it up as a winter/training bike. I have got all the parts to start putting it together but now I see there is a Thru Axle version of this frameset and there is an ex display model for sale at a very good price.
My questions are, will I see a big difference between the two axle standards and is there any issues with running a QR disc bike that thru axles eliminate?
Many Thanks
Many Thanks
I started with post mount disc brakes on my MTB and CX bike before thru-axle become the standard. After a couple instances on my MTB were I did not feel like the quick releases were clamping the front dropouts as well as I wanted, so I opted to use DT's RWS thru-bolt axles. Fast forward a few years, and we now have road and gravel bikes with thru-axles and flat-mount disc brakes, and while I would not go back to QR, as I get the surplus disc-brake CX bike with QR ready for sale on Ebay, I do find it much easier to center the post mount calipers compared to the flat mount, but the thru-axles ensure the same rotor alignment and afford a much better sense of security about not having the front wheel come off under heavy braking.HillClimbTom wrote: ↑Tue Dec 10, 2019 11:13 pmis there any issues with running a QR disc bike that thru axles eliminate?
- Michael
I built up the older 4S with QR flat mount hyro disc
TBH had no issues, even rode a 235km / 4000+m fondo with a stack of climbing and decending
Occasionally I would get some pinging in damp weather
Likewise if their was some slight rub after a hard brake into a turn a quick tap on the brake to re-allign would fix it
As I was always popping out the front wheel to put my bike in the car though
The only thing I did each ride was slot the wheel in and squeeze the brake before tightning the QR
- Contact:
As long as the standard hub width stays at 100mm, adapting a thru axle wheel to a QR fork will remain quite easy. If it goes to 110mm, those with 100mm thru axle forks aren’t going to fare any better than those with a QR fork.
I have ~25k road miles on a QR disc fork from 2008 without any issues of the wheel coming loose. Be consistent with installing the wheel (put pressure on the handlebars while tightening the QR to be sure it is fully seated) and make that QR nice and tight.
Thanks for the comments so far.
I think I'm going to build up the QR frame and see what happens. As for future proofing myself, I have already thought about that. I have got hope hubs which can be adapted to pretty much any standard.
If anyone else has any advise or experience running either setup then shout up. It's going to take me a while to get it built, so still time to change.
My 4s is the older style and I run qr. Very rarely I get front end pings but that typically only happens if I haven't taken due care to centre the wheel.
I have the wheels off several times a week and I don't have real issues centring then when I refit them.
I've never felt any significant flex in the front end. The tracer fork is pretty overbuilt, I don't think a through axle would make a tremendous difference.
By comparison, I have a tripster cx and I don't think the axles are particularly nice to work with.
Personally, I'd take the cheap option because i don't think it makes that much difference in performance.
My Crockett is a first-year model, with QR's, both front and rear. I eliminated the disc rub by using DT Swiss RWS QR skewers. You just tighten the skewers until the wheels are snug, and adjust the cam. It acts much like a 5mm thru-axle.
Unfortunately, the skewers aren't the lightest option out there, but they're much more stable than traditional QR's.
Madone 9 - https://bit.ly/2Nqedbn
Emonda SLR - https://bit.ly/2UK5FP8
Crockett - https://bit.ly/2Xem4sk
I have the old 4s that takes QRs and can be built either disc or rim brakes. I went for rim brakes because it is what I had at the time.
I've also got QR disc brake bikes. Never had a problem so long as I'm using heavy-duty QRs like Campag or Shimano. WOuldn't be happy to use light ones like KCNC, tune etc with discs.
I'd say build with what you have. The TA version is slightly better, but it isn't worth fussing over if you already have the QR version of the frame.
I think it's ridiculous that road MFGs are claiming that QRs aren't good enough for disc use. They were used for years in MTB and it was really only downhill that brought on thru axles, then 12x142, and now 12x148. I've ridden plenty of QR and TA mtbs and I'd say there are so many confounding factors in stiffness that it's impossible to level it just to axle. I certainly have never had a wheel drop out, and that's in actual mountain biking, not road riding.
Anyways...my next bike is TA, sure enough. It's part of the complete package, and if I had to buy new wheels anyways, I may as well get ones that are most forward compatible. I do think having thru axles helps, but it's not going to revolutionize your ride.
I got an insane deal on my S-Works Crux because it was "old tech" with quick releases. This Crux rides great with zero complaints. I'll probably ride it until it dies since I don't see any other game changing tech coming along yet.
I have QR now. Works great for me, no issues. Moving forward I'll be looking into TA for my next bike.
His: Orbea Orca OMX
