What size rotors do you recommend?
joejack951
by joejack951
Nikoras wrote:
Thu Dec 12, 2019 5:02 am
joejack951 wrote:
Mon Dec 09, 2019 5:04 pm
I still think anyone 'cooking' a 140mm rear rotor on the road needs to evaluate how they brake.
Nah, if you're riding unfamiliar roads with big descents and poor visibility it will happen. No need to be a dick about it.
I've talked with quite a few 'experienced' cyclists who think the rear brake is the best one to use to stop quickly. I'm not saying you're one of them but in the past it has benefited the discussion to mention that the front brake is the more effective one to use. If you already know this, my apologies for coming off like a dick. I should work harder at re-reading my post to avoid sounding dick-ish.
dricked
by dricked
I ride 140mm rotors at 80kg. The terrain is rolling hills with no technical decents (unfortunately) so the rotors don’t really get a workout. A few hard stops after 60-70km/h hills and stop signs and they work just fine.
Obviously terrain/rider weight dictate rotor size.
icantaffordcycling
by icantaffordcycling
From VeloNews
Does anyone know if these are a Shimano part or a custom part? I am guessing that if they were a Shimano part more teams would be using them but it looks like it just replaces the stock flat-mount adaptor. Looking at the 360 view on the Merida site, it doesn't look like it comes with the reacto or sulctura.
by Nefarious86
They would be specific to the frame.
As for rotors I find at 180lb 160/140 gives a nice balanced feel without having an easily overpowered rear brake.
Sent from my SM-N976B using Tapatalk
Using Tapatalk
TobinHatesYou
by TobinHatesYou
Merida has been using those fins for at least 2 years.
One thing that was pointed out to me last weekend by one of icantaffordcycling’s teammates is how fat the carrier arms are on the Shimano DA rotors compared to those of the SRAM Centerline XRs.
spdntrxi
by spdntrxi
icantaffordcycling wrote:
Thu Jan 23, 2020 7:41 pm
From VeloNews
looks more like a fairing to me... but I guess if you dont call it a fairing it's more likely to approved by the UCI.
Dan Gerous
by Dan Gerous
I'm pretty sure those are not fairings or to disrupt air on the Meridas, they're heatsinks. If the front caliper gets hot, heat transfers to the heatsink/mount, the bigger the heatsink and the more surface area it has, the more it can help release the heat, and having air flow on and through it helps this, how much though, no idea...
TobinHatesYou
by TobinHatesYou
Also the NDS chainstay also has fins in a vertical orientation. They’re obviously heat sinks, come on.
TheRich
by TheRich
Looks like woo to me.
I finally broke down and went 160/160, although most of the reason is because it's a dual purpose road/gravel bike, it does make spares easier to deal with.
