1st attempt at WW build
Crankycolnago
by Crankycolnago
This will be the first we build I do, most of my bike have been great builds but really never focused on beign super light .
2020 TCR adv ISP , small
Giant integrated bar and stem
Selle Italia c-59 saddle
Will be going w etap 11 speed including quarq pm and giant wheelset . Hoping to be below 15 lbs . Missing bottom bracket and cages so far
spdntrxi
by spdntrxi
sub 15 is not a shoe in with parts shown and stated ....GL
shotgun
by shotgun
Great start! I'd say you'll definitely be around the 15-16lbs territory. White will look so clean.
2018 Giant TCR Advance SL0 Disc
2017 Festka Scalatore
1989 Battaglin Roche
1985 Alan Carbonio
refthimos
by refthimos
Agree, the TCR Advanced is a fantastic frame, but there is no getting around the fact that disc brakes are going to cost you significant weight. My TCR came in at 7.35kg, or 16.2 lbs. Sure, you have an advantage with your smaller frame but after that, the biggest place to drop weight is with the wheels, and your Giant wheels aren't particularly light. The next place to save some weight would be in the crankset - what do you plan to use? After that, the potential weight savings start to get quite small...
EVO1 | 5.37kg
EVO3 | 6.51kg
SystemSix | 8.01kg
P5 | 9070 Di2 | SISL2 SRM | Enve 7.8/FFWD Falcon | Roval 321
T1 | P2Max Type S | Rolf Prima FX58/Zipp Super 9 Disc
Noctiluxx
by Noctiluxx
I would skip the current heavy integrated handlebar and wait for the replacement coming in the next month or two. It will be at least 100 grams lighter and look much better. There is some guy in Taiwan selling them on eBay right now. Link for pics of the bar is below. Also I have a friend who just built a 2020 TCR SL (small) with eTap, Black inc 30mm wheels, Giant carbon bar and carbon stem. While your saddle is a lot lighter than his Fizik, your wheels are a lot heavier. His bike with Shimano pedals (not sure which model), bottle cage, is 16.2 lbs.
https://www.giant-bicycles.com/int/cont ... p-bar-2020
2018 Bianchi Oltre XR4, (Celeste Matt)
2018 De Rosa SK Pininfarina (Blu)
2019 Trek Madone SLR (Rage Red)
2019 Giant TCR Advanced SL (Chameleon Blue)
2019 Cervelo R5 Disk (Team Sunweb)
2019 Giant Revolt Advanced 0
Crankycolnago
by Crankycolnago
Yea wheels are going to be the issue , gonna have a set of enve 3.4 built soon but may be about the same weight
Noctiluxx
by Noctiluxx
Crankycolnago wrote:
Thu Dec 05, 2019 3:57 am
If you're in So Cal, you can buy any Enve wheelset with the Enve alloy hub for $1700. I did, along with 5.6 disk and 7.8 clinchers.
shotgun
by shotgun
As mentioned, the handlebar is on the heavy side. here's the weight of my 42cm at 352g.
A shallower SLR0 30 is the lighter of their wheels at sub 1.4kg but you've got a number of options as well.
1985 Alan Carbonio
Ferry
by Ferry
I will be following this topic. Just ordered an TCR advanced sl disc frame myself. Not sure what cranks to use and looking for suggestions.
shotgun
by shotgun
Not to hijack the thread, but I was able to get to 6.8kg by using Dura Ace groupset, Sworks saddle, Giant SL handlebar & Kalloy OD2 stem, Look keo carbon ti pedals, Reynolds Attack wheels, Ashima Ai2 rotors and some selected bar tape, chain and cables.
1985 Alan Carbonio
Crankycolnago
by Crankycolnago
What are people using for light direct mount rotors ? Can't seem to find much out there .
Crankycolnago
by Crankycolnago
Who did you get them from ?
Noctiluxx wrote:
Thu Dec 05, 2019 4:45 am
Noctiluxx
by Noctiluxx
Thu Dec 05, 2019 3:27 pm
Two options. Competitive Cyclist currently has Enve 3.4 with DT Swiss 240 on sale for $1449 plus tax or buy the wheelset with Enve alloy hub for $1700 out the door with alloy wheel trade program through my dealer in Ventura.
https://www.competitivecyclist.com/enve ... EwMDA2OA==
prebsy
by prebsy
shotgun wrote:
Thu Dec 05, 2019 9:18 am
where did you get a kalloy stem for OD2/ 1.25 steerer?
Strava
Current Stable:
Specialized Allez Sprint Disc
Cervelo Aspero
Scott Spark 910 Contessa
shotgun
by shotgun
Thu Dec 05, 2019 3:26 pm
I used Ashima adapters and Ashima Ai2 140mm rotors
1985 Alan Carbonio
