Shimano XTR CN-M9100 chain on 9100 series Dura Ace
the largest sprocket on the red xg-1190 cassette is wider than all the other cogs, has anyone tried had success using the xtr chain with it?
It works fine.ohexploitable wrote: ↑Tue Sep 07, 2021 4:35 pmthe largest sprocket on the red xg-1190 cassette is wider than all the other cogs, has anyone tried had success using the xtr chain with it?
- robbosmans
- Moderator
- Contact:
Use 2 quicklinksMaddie wrote:Am I right that there are no Shimano 12s chain pins? I need to extend my xtr chain but don't want to use 2 quicklinks on the same chain. Thoughts?
Nothing wrong with using 2 quick links and a section of chain in between. Works perfectly and you will be the only person who knows.robbosmans wrote: ↑Thu Sep 09, 2021 9:36 amUse 2 quicklinksMaddie wrote:Am I right that there are no Shimano 12s chain pins? I need to extend my xtr chain but don't want to use 2 quicklinks on the same chain. Thoughts?
Giant Propel Advanced SL Red Etap 11s Easton EC90 wheels CeramicSpeed BB Zipp SL70 bars 6.5kg
Vitus ZX1 CRS Campy Chorus 12s Bora WTO 45 disk brake wheels Zipp SL70 bars 7.5kg
SL8 build with Craft CS5060 Wheels in progress
You don't know my eagle-eyed friendsNickldn wrote:Nothing wrong with using 2 quick links and a section of chain in between. Works perfectly and you will be the only person who knows.robbosmans wrote: ↑Thu Sep 09, 2021 9:36 amUse 2 quicklinksMaddie wrote:Am I right that there are no Shimano 12s chain pins? I need to extend my xtr chain but don't want to use 2 quicklinks on the same chain. Thoughts?
Simple solution: don't use an Eagle 12s chain!Maddie wrote: ↑Thu Sep 09, 2021 10:22 amYou don't know my eagle-eyed friendsNickldn wrote:Nothing wrong with using 2 quick links and a section of chain in between. Works perfectly and you will be the only person who knows.robbosmans wrote: ↑Thu Sep 09, 2021 9:36 amUse 2 quicklinksMaddie wrote:Am I right that there are no Shimano 12s chain pins? I need to extend my xtr chain but don't want to use 2 quicklinks on the same chain. Thoughts?
Of course it is. That would generally require 113 links.
IG: RhinosWorkshop
IG: RhinosWorkshop
- robbosmans
- Moderator
- Contact:
Something else is wrong then, it should shift great. Derailleur hanger, cables, index…
