Frame with steep angles (HT...)
moock
by moock
Hey guys,
do you know any bikes (framesets) with steep Headtube and Seattube? 73.5 - 74deg in size 56/58/L/XL
my list so far:
-Spesh tarmac (meh dont like the brand)
-Felt FR (frameset is just too expensive @4k)
-Canyon Ultimate
do you have any more ideas? I would apprechiate non aeroframes as the geo most time is too agressive for my bodie.
thx :-)
DaveS
by DaveS
Why would you want that? Most brands have similar geometry because it works.
moock
by moock
DaveS wrote:
Wed Nov 27, 2019 4:22 pm
steeper ST to come more foreward. I already use 0mm setback.
steeper HT for sharper cornering.
Hexsense
by Hexsense
Sharper cornering is more of product of trail, more than just steep HTA alone.
Look for frame with low trail value. 72-73 HTA with high fork rake can corner sharper than 73.5 deg with low fork rake.
Karvalo
by Karvalo
moock wrote:
Wed Nov 27, 2019 4:37 pm
Just out of interest, what bike are you comparing it to, and why do you want it that sharp?
mrlobber
by mrlobber
Benotti (AX Lightness) Vial Evo Ultra has 73.5 deg HT / 73.5 deg ST @ size 56.
Retired bikes: Cervelo S5 2015 / Felt AR FRD 2014 / Cannondale SS HM 2014 / Scott Addict SL 2014 / Scott Plasma Premium 2014 / Orbea Orca 2008 / Look 596 /
Mr.Gib
by Mr.Gib
Careful with this. With a given fork offset, steeper head tube angles make the bike less responsive to lean. If you want a bike to turn in and hook up in a carve with a minimum of effort on your part, that you want a more slack head tube angle. Bikes with more upright head tubes can be very agile and tossable, it's just that when it comes to high speed cornering, descending, they will require more lean. The upside is that they require less precision on the part of the rider. They can be very stable in all situations and very hard to "upset".
moock
by moock
Karvalo wrote:
Wed Nov 27, 2019 8:00 pm
currently i have an Allez Sprint. It is pretty ok and i dont want less sharp feeling
moock
by moock
mrlobber wrote:
Wed Nov 27, 2019 9:43 pm
Sadly, i cannot handle this geometrie! My legs are just huge so the stack will be too low
mrlobber
by mrlobber
578mm is too low, really? More than 20mm higher than Allez Sprint 56 and just 5mm lower than Allez Sprint 58.
Anyway, as others have commented, HT angle in combination with fork rake & tyre size (which together determine trail) will (mostly) be resposible for bike handling in corners.
muti
by muti
Trek emondas have pretty steep headtube angles,matched with 40mm rake to give neutral steering.56 has 73.3 seatube angle and 58 has 73 and relatively high stack heights. Ritchey logic 57 has 73.5/73.5-43 rake and 587mm stack height(although I understand it's not a type of frame that you are looking for).
Etienne
by Etienne
mrlobber wrote:
Thu Nov 28, 2019 7:52 am
As the OP suggested he has very long legs, I guess he has also his saddle set quite high ... 578mm would then be too low indeed.
For instance, I am 183cm with a 93cm inseam ... my saddle height is set at 80cm (relatively low considering my inseam by the way) and any bike with more than 395mm of reach and less than 595mm of stack is too low AND too long. Furthermore, being short torsoed, I have a relatively limited setback and need a ST angle of 73,5°or more, see here to understand why : https://www.stevehoggbikefitting.com/bi ... oad-bikes/
If you can find a frame that is at the same time : short, tall and racy ... perhaps is this what Moock is looking for :idea:
alcatraz
by alcatraz
Hexsense wrote:
Wed Nov 27, 2019 5:59 pm
This!
Ignore HT, look at trail in the geometry chart. The fork design can make a shallow HT corner sharper than a steep HT.
