Any Cervelo R5 Disk owners out there?
Noctiluxx
by Noctiluxx
On a whim, I decided to order a Cervelo R5 disk Team Sunweb team frameset at an incredibly low price of $2000 from Bike24. I always loved the Sunweb team bikes and lucked out at this price. For owners of this bike, can you tell me what are the strenght and weaknesses of this bike? BTW I plan on building it with Dura Ace 9170 di2 and Bora WTO 45mm wheels. This will be my first disk road bike. Thanks!
2018 Bianchi Oltre XR4, (Celeste Matt)
2018 De Rosa SK Pininfarina (Blu)
2019 Trek Madone SLR (Rage Red)
2019 Giant TCR Advanced SL (Chameleon Blue)
2019 Cervelo R5 Disk (Team Sunweb)
2019 Giant Revolt Advanced 0
jlok
by jlok
It's a cracking deal! or is it the "proper" price of a bicycle...
Heard loud noises coming out of the Matthew's S5 if my memories are correct (many have questioned the Cervelo marketing team to allow such a clip to be published on YouTube). If R5 is coming out of the same factory as S5, you may consider using one-piece or the thread-together BB, just not the press fit.
uraqt
by uraqt
Dam it!! I was hoping that nobody found that price untill, I saved up!!!
jlok is right the BBright is the weekness, I have done tons of research and have a R5 .. this is the best solution ..
https://www.bbinfinite.com/products/bbr ... 9864604227
C
mrlobber
by mrlobber
It's all ok with R5's BB. In fact, that might be the best BB of any Cervelo to date (definitely, comparing to earlier, pre-2015 models), as it is a completely solid carbon shell.
I did initially have creaking, but eventually tracked it down to not-too-well tightened RAT axle.
Other than it, the bike is a really solid one; and for $2000, the frameset is a steal.
The creaks in Matthew's S5 most likely came from the steerer-stem-handlebar assembly. It's maybe the best fully-integrated solution I've ever seen, and a really stiff one too, but it does have a tendency to creak, unfortunately.
Retired bikes: Cervelo S5 2015 / Felt AR FRD 2014 / Cannondale SS HM 2014 / Scott Addict SL 2014 / Scott Plasma Premium 2014 / Orbea Orca 2008 / Look 596 /
kervelo
by kervelo
I think there are many bottom brackets that, if installed correctly, don't cause any issues with the Bbright. My favourite is the C-bear from Belgium.
https://www.c-bear.com/
The C-bear cups are not glued with loctite etc., they are just pressed using anti-seize paste.
icantaffordcycling
by icantaffordcycling
Don't use the stock cervelo headset expander. But as a WW I doubt u would have even considered it.
