Weight weenie parts that actually worked!!!
mkentik
by mkentik
We are going good
Points Given as per times of appearance basis on work, functionality and durability as follows
1)AX lightness saddles
2)Bontrager xxx saddle
3)Darimo loop seatpost
4)Cane creek EE brakes
5)Extralite Ultrastar expander
6)J&L Ti Speedplay spindles
7)MCFK handlebars
8)MCFK seatpost
9)Sram Red cassettes
10)Tune wassertrager bottle cages
up to now parts that didnt worked and appearing many time are:
1)Extralite Streeters
2)UNO Stems
3)Schmolke seatpost
Keep them going guys!!! :welcome: :welcome: :welcome:
[Pinarello Dogma F8 Disc]
[Colnago Master Oval Titanium]
[Cicli Barco XCR]
[Gios Compact Evolution]
tabl10s
by tabl10s
Extralite rings, THM Tibia/Clavicula, Schmolke TLO bar, Mcfk stem, Selle Italia C-59, Gelu P1, Tubolito's, Jagwire Elite, Look Keo Blade 2 Ti, KCNC DMD chain, Carbonworks bottle holders, Cane Creek ee's/AER II/110, Rotor Quarbon rings/Uno cassette.
2015 Pinarello F8: 13.13lbs/5.915kg(w/Roval 64's).
2016 Rca: 11.07lbs/5.048kg.
2018 Rca.
2018 S-Works SL6 Ultralight: 12.03lbs.
Beancouter
by Beancouter
Eecycleworks brakes
Ec90 saddle (Ali express) - unpadded carbon ‘power’ shape
Sram exogram cranks - bb30 uber light
Ward Ti spindles for speedplay pedals
Tubolito inner tubes
Cannondale SL compression plug (headset)
RocketRacing
by RocketRacing
Ee brakes
Darimo t1 post
Darimo loop saddle loops
Berk saddle
Darimo subzero seatpost clamp
Wren stems (even for a fatbike)
Darimo mtb and road bars
Tri rig aero skewers
Garmin 130
Raceware garim mount
Cane creek aer headset bearings
Carbonwerks bottle cages
Elite superfly bottles
Carbon ti xhubs
robertbb
by robertbb
What are the issues with the UNO stem?
dereksmalls
by dereksmalls
Wert skewers
Dario T1 loop seatpost
Berk saddle
THM Clavicula SE
Darimo Eclipse road bar
EE brakes
Carbonwerks cages
Ward Industries ti spindles
Vredestein latex tubes
alcatraz
by alcatraz
robertbb wrote:
Thu Nov 21, 2019 12:38 am
Seems its not a widespread issue but just a personal issue to me.
It's that the clamping surface is relatively small with possibly sharp edges or something, causing the pressure onto the bars to be higher at a given torque on the bolts. Add vibrations and potholes that over time cause the bars to delaminate around the clamp area. Just use as much torque as you need and take note if you need to tighten the bolts after a while. It could be the beginning of delamination.
I have had several uno6/7 stems and I still use one today with a handlebar that isn't ultralight. With that it seems to hold up fine. Take care with ultralight bars however.
robertbb
by robertbb
alcatraz wrote:
Thu Nov 21, 2019 5:25 am
Thanks alcatraz. I refuse to use carbon bars anyhow - all alloy here, have been for some time :)
NiFTY
by NiFTY
Worked
Mcfk stem
Thm ulna bars
Darimo t2 setback post
Ee brakes
Extralite streeters skewers ( but have had to replace cam plates)
Kcnc skewers(old version)
Extralite ultrastar
Ax ultra 25t
Tune wassertrager uni cages
Segmented housings (ilink, mini ilink, elite link, powercordz swift)
Kcnc ti brake cables
Extralite pulleys mostly
Tune carbon shifter clamps
Fsa sl headset bearings
Not worked
Carbonice seatpost - saddle kept coming loose at clamp
Extralite pulleys for lower pulley wheel (thrown chain with 10 and 11t - nil issues w 12t narrow wide)
Tune skyline skewers(alloy axle) - never felt secure enough
Kcnc ti shift - multiple snapped cables
Newer kcnc skewers w polymer cam - they crack
StevenH72
by StevenH72
What Worked:
Schmolke TLO Seatpost
EE Brakes
4iiii Power Meter
Carbonworks Bottle Cages
burglarboycie
by burglarboycie
What's worked for me:
eBay Bontrager xxx replica cages
J&L thru axle
Hylix seatpost (27.2 & 25.4)
What's not worked:
J&L alloy bottle cage bolts - had some good sets but the last ones I bought were badly made and couldn't fit an allen key in the head. Had 1 snap on me too once.
LouisN
by LouisN
Kayrehn wrote:
Wed Nov 20, 2019 7:31 am
alcatraz wrote:I'd like to issue a warning on uno stems. They can dig into carbon bars. I used carbon paste and gentle torque, but it was still inevitable. Sure they were cheap bars but still take care. If you find having to tighten the stem bolts after a few months that's the first sign.
There was a thread on carbon bars that get indentations previously - even my heavy Zipp bars get those marks from a Zipp stem, while my light weight Haero carbon bars were removed from its Uno stem without any marks at all after 3000km.
Yep, exactly. Uno stem is fine. The "didn't work" should have been about those cheap bars ;) .
Louis :)
Etienne
by Etienne
Not a big fan of superlight parts in general, but I used those with success
Carbonworks bottle cages
BTP bottle cages, now discontinued
Ward and J&L titanium spindles for Speedplay pedals
Kalloy Uno stems
Also tried superlight seatpost clamps, always had problems and went back to heavy Thomson seat clamps ... security and peace of mind first :wink:
Lewn777
by Lewn777
What works:
-Ti or alloy bolts in as many places as possible. Steel is heavy. Particularly on seat post bolts can be huge.
-K-Alloy Uno stem.
-Alloy brake and shifter housings, but only in straegic places like RD loop, frame into rear brake and front brake because they can creak.
-DT Swiss Ti skewers (not ultra weenie but safe).
-'welterweight' 70g butyl tubes, again not mega weenie, but strong enough to do the job and light enough.
-Carbon saddles like Arione 00.
-Bikes with rim brakes, as they are a cheap way to stay light - trying to weenie some disk brake bikes is a headache.
-SRAM Force 22 or RED groupsets, athlough not sure about SRAM brakes and GXP cranks. Maybe run DA brakes and cranks.
-Ti cassette lockring.
-Ti cleat bolts.
-Slamming stem.
KarlC
by KarlC
EE brakes
SRAM Red cassettes
Berk saddles
deCADENce tubular wheels
