That is a very elegant design, bravo!joejack951 wrote: ↑Wed Nov 20, 2019 4:44 pmYup, I went so far as to design my own conversion headset to allow use of threadless stems while retaining the original threaded fork. Two examples of bikes I've built with the headset:CrankyCarbon wrote: ↑Wed Nov 20, 2019 3:35 pmThe main advantage you'll have is that you'll be open to modern 31.8mm handlebars.
I upgraded to get newer, lighter aero handlebars from my 26.0 or 26.4 Cinelli Ergo bars and Cinelli XA stems.
My original aheadset stem on my one bike allowed me to use my Cinelli Ergo bars.
But all the new fancy, aero alloy, carbon etc need 31.8mm stem. So I made the changes. I'm glad I did too as I think this is your main advantage.
The hollow alloy, carbon or carbon/alloy stems seem much stiffer too.
At the moment a cheap 100 gram ahead stem + the full height Innicycle system (265 g) comes to 365 grams in total.
The lightest quill stem is still the 200 grams Cinelli Grammo and a lightweight 1" threaded headset is about 90 grams - e.g. Tange Falcon, so about 290 grams in total. (75 grams lighter)
The lightest readily available quill adaptor weighs 142 grams (Deda) - if you can find a Cinelli one, they are much lighter but extremely rare. So 142 + 100 + 90 = 332 grams for a competitive system to the Innicycle. (33 grams lighter)
I'm curious what the minimum weight would be if you ride with a slammed stem and fit a Titanium bolt. Would it be possible to remove more than 75 grams in total after cutting the unit down to size?
