I don't know what you have against me but for info the test tyre has not changed yet.RocketRacing wrote: ↑Thu Nov 14, 2019 9:14 pmThe trend is back to non-terroidal shapes as seen in the raynolds wheels above. Part of the design behind terroidal was more about wind stability and side forces, not just aero gains. The idea was that the leading edge and trailing edge had similar appearances to the wind. So side forces would not torque the wheels as much... or so was the theory.
But in the end, you want a shape that replicates an airfoil. The trick is that airfoil is reversed on the trailing edge of the wheel. But then airflow has already been disturbed... so maybe it does not matter as much.
Terroidal are not as good as a leading edge, but better as a trailing edge.
And the linked hambini video (god i hate him) relates to the alpha angle i was referring to prior. I.e. the wider the tire, the deeper the rim must be to recapture disturbed air. But he basically reinforces the rule of 105 by advising against tires being wider than a rim. Different rim shapes will tolerate tire sizes differently, so the rule of 105 will vary based on the rim shape/depth. Of note, this is a flaw in his wind tunnel data imho as he used gp4000s2's in 23c at 120psi or something moronic which would put them at 26-27mm wide easy on many of those wheels. So assuming his data is valid, the test is as much about how a rim handles a tire at that width than anything. Don't quote me, but Since then i think he has swapped to testing with a gp5000 that is narrower, and not as aero... so it kind of invalidates any data comparison. But i may be wrong on his protocol changing.
To clarify this statement to anyone else who is reading so the rule of 105 will vary based on the rim shape/depth.
It's essentially no longer a rule. My guidance is as follows
Pick a tyre that is no wider and ideally the same width as the rim
Ensure the minimum rim depth is as follows:
23mm tyre -> 45mm minimum rim depth
25mm tyre -> 55mm minimum rim depth
28mm tyre -> 80mm minimum rim depth
Picking a rim that is wider than the tyre is no where near as good as getting one that is level.
Thanks
Hambini
