Sigeyi Axo Power Meter Spider
velolive
Re: Sigeyi Axo Power Meter Spider
Post by velolive »
alphara wrote:
Mon Jan 13, 2020 1:01 pm
could someone with a sigeyi power meter do a small L/R balance test?
push lap button, pedal but push much harder with just the right foot for 1 minute and end the lap. Check what it shows as the L/R balance.
I would like to know if my unit is faulty or if its just the software problem. It shows 50-50 or 49-51 for me with this test.
Wait for the new firmware, it has to be available soon.
g32ecs wrote:
Thats 100% faulty. The other arm should be reading 0 on your computer.
Spider based powermeters do not show real balance, it an "advertisment feature"
Imho
DC Rainmaker Quarq test, start from 0:45
alphara
Post by alphara »
with the DC rainmaker test the quarq will show some power from other leg too as you have to pull the crank on the opposite side as your other foot is unclipped.
alanyu
Post by alanyu »
I've updated to the latest firmware which is claimed to solve the L/R problem. I will have a try after work.
Hexsense
Post by Hexsense »
alphara wrote:
Wed Jan 15, 2020 2:27 pm
Yes.
Only if you push down twice as hard and the left over momentum carry the pedal through the up stroke without pulling up then the Spider based can get left/right balance right. As soon as you have to pull the pedal up too and also apply slicing force on the top and bottom of pedal stroke, the spider based power meter will get it wrong.
dudemanppl
Post by dudemanppl »
Few things to note after the few hundred miles I've put on it:
As above, L/R balance is useless, but I haven't updated to the newest firmware, so that may change.
I also get random big power spikes once or twice a ride. Well not that random, its always when I get off from a light/stop sign.
I'm not sure if I can 100% trust the power data from it yet. Judging versus my historical power data it seems to be usually ballpark, but some efforts on the same ride will be lower, others will be higher. May just be different conditions to be honest. Hard to tell!
alanyu
Post by alanyu »
Fine, I also failed to have a easy test with the latest firmware.
I thought I had successfully updated the firmware to 4.X which is claimed to fix L/R issue, but when I turned on my Garmin yesterday after work to see the details, it was still fm 2.5 version. Definitely wrong L/R estimation as it still showed near 50/50 in 90% time when I unclipped either foot or stroke hard on either side.
Asked the official seller about why it failed in updating and was told that the service is under maintenance.
One more thing is about the fast pick up of the data. I asked them how does AXO measure the cadence and was told that it measures each 90 deg instead of each 180/360 deg. It benefits in the accuracy of using oval chainrings.
vanmatthew
Post by vanmatthew »
Reading through this. Are people just buying this through Aliexpress.
alphara
Post by alphara »
vanmatthew wrote:
Fri Jan 17, 2020 6:30 pm
I did, got 1 and waiting for 2nd one
checky
Post by checky »
Are these PMs also available for Race Face cinch cranksets?
alanyu
Post by alanyu »
checky wrote:
Thu Jan 23, 2020 5:47 pm
Yes, I saw some easton ec90sl cranks with axo in china. Easton and RF use the same cinch intetface.
alphara
Post by alphara »
After 2.6 update the left/right balance is working perfectly. Did the test yesterday - I was pedalling with both feet but pushed much harder with one foot, got 80%/20%
dudemanppl
As above, I updated to 2.6 yesterday and it seems to be reading L/R well now. I also am happy with the accuracy and repeatibility of it and would recommend it whole heartedly. It seems that some sellers on Aliexpress are selling the Xcadey counterpart for 260!
addictR1
Post by addictR1 »
Looking to pull the trigger one one. How’s the battery life? My stages drains like crazy even with the updated FW.
Also what the weight of these compared to stages? Thx
ghd
Post by ghd »
addictR1 wrote:
Tue Jan 28, 2020 9:38 am
Mine is going to reach over 100h of riding time according to the current battery level and elapsed ride time.
addictR1
Post by addictR1 »
I have the sram red crank with bcd110. So I take it I’ll need the 5 hole 3 bolt version right?
